W203 C200K water in coil well #2
Old Mar 3, 2022 | 12:09 AM
YahiaShowgan's Avatar
W203 C200K
Hey!
Few times now, every few weeks i get a 'Misfire in Cylinder 2' fault code and i remove the coil and find the coil well filled with water that looks like rain water (No smell or color so i presume it's not coolant). All other 3 coil wells are dry and when i dry it, it works great for few weeks and then it gets filled again.
I tried to check some of the water drains none of them look clogged but maybe i'm missing one? Any other ideas?
Old Mar 3, 2022 | 02:39 AM
jggarcia.vc's Avatar
2005 C230 Kompressor Sedan, 2003 CLK55 AMG, 2021 GLC300
How is water getting into the spark plug hole? do you keep the car outside is it raining?
I used to get this problem when I would wash my engine bay.
1. The coil pack sleeve where worn out/cracked.
2. My Cover was not snapping into place one of the clips on the valve cover was broken.
3. The upper cover gasket for the valve cover was also severely brittle and worn Part # 271-016-08-21
These issues with me pressure washing it caused water to leak into the spark plug cavities. Since than i've replaced 1 and 2 and have ordered the cover gasket but also have not washed my engine bay in a few months...
Not sure how you are getting so much water in there are you missing the hood? It's very strange... if it's infact just water... now if your leaking coolant well.... that's awhole different scenario...
Old Mar 3, 2022 | 03:15 AM
W203 C200K
I'm not washing the engine bay, it has been raining every few days for the last months i believe it is from the rain. And the car is always out in the rain.
Old Mar 12, 2022 | 02:43 PM
W203 C200K
Any ideas?
Old Mar 13, 2022 | 04:03 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
It seems to be an oddly specific place for water to collect. There is no vent there at all.
You mentioned you aren't washing your engine, so I'll rule that one out.
1) Is your engine cover installed and undamaged?
2) Are you losing any coolant?
3) Are all rubber seals in the engine bay installed? Specifically the long wavy one below the wipers at the bottom of the windshield. Long shot but might as well ask.
4) Any other consistent wet spots in the engine bay?
5) Any damage in the hood insulation?
Old Mar 25, 2024 | 03:27 AM
cyto's Avatar
c180
Hi did you ever solve this as I am having the same issue in a C180
cyto [phil]
Old Mar 26, 2024 | 06:33 AM
W203 C200K
cyto [phil]
There was some clip missing down on the hood air vent or something, which water was getting through if i'm not mistaken.. pretty sure it was fixed after i sealed that.
Old Jul 21, 2024 | 07:11 AM
Sammo Sheriff's Avatar
C230
W203 water in coil
I realized the issue was related to the engine cover (the one with the Mercedes Benz inscription). After peeling off the foam inside, I noticed a space around the clip holding the Mercedes Benz inscription.
To prevent water from dripping directly onto the coil when it rains, I used a plain sticker to cover the gap. We are currently in the rainy season, I haven't experienced the problem again.
