Need help with a couple of issues on C Coupe
Just got my car back from the dealer for the same issues they can not resolve.
First - the car has a surge that some days is pretty bad and some not. It is most notable at ~2000 RPM at steady throttle. Also, sometime when leaving in 1st gear, the car "bucks" like the motor has been shut down for a second, then back on.
I am tired of the dealer saying there is not problem. They did admit to it two times and even replaced the computer, but now "the car is fine and we don't see a code on the computer".
Second - I have the classic jump out of first gear problem if I don't get the shifter passed both clicks. On one forum people have gotten this fixed by a gear oil change. Anyone here been through this? The Crossfire video from UK test drivers had this problem. Of course MB dealer has never heard of it....
Third - Is the connection (electronic) between the throttle pedal and actuator that opens the throttle body linear? On my car, when I take my foot off the throttle, it takes a full second for the engine to respond. I think this issue and surge are related - possibly a bad throttle body actuator.
Any help would be great.
I agree that 1 and 3 could easily be part of the same problem. A full second to wait for the engine throttle to back out sounds really dangerous to me. My throttle backs off instantly. Don't know what to suggest though.
Yes my 1st to 2nd shift has been rough and they know it is a problem. Like yours at 13,000 miles mine is getting better. The issue with 1st is it has two defenite clicks to fully engage 1st gear. If I am not paying attention and only get passed the first click, it will jump out of gear under power - WAM. People riding with me think it was hit by another car. I can't remember another standard car that had two clicks into first so I really have to watch it. But, like the 2nd gear break-in the double click is getting less noticable. Yes, if you got from 2nd to first it will help align the gears up as they slow. The 1st gear jump happens from a full stop when sitting at a stop with trans in neutral and it don't push hard enough to get passed the second click.
So your throttle backs off instantly..mmm and as it should. I did raise the safety consern with the dealer only to deaf ears. Time to call MBUSA.
I guess I should not complain too much. My friend bought a BMW 330ci convertable for $46K the same time I bought the MB and has had it towed in 4 times for electical problems.
and they recently replaced the entire fuel injection system to fix it.
After which the car has been kinda wimpy...in the shop now for SRS error, so see if they can get it pumped up again.
So, what common problem does the TCU cause?? Surging?
I will call MBUSA this afternoon and let you all know the results.
Cool...
the regional tech guy in my area has been really good to me....
got the dealer of their butts.
