C180 kompressor idle issue
Old May 6, 2022 | 10:38 AM
WurminatorZA's Avatar
2006 Mercedes-Benz C180 Kompressor
Im having this strange issue since replacing the $12 hoses (wasnt a problem but thought of doing it anyway as i was changing serpentine belt). Car feels like it doesnt have much boost, also sometimes when coming to a stop the rpm stays at 1200rpm until i either pull away and change gears or by its own but completely random. It idles at about 900rpm which I think might be higher than it did before work was done. I have tested for vacuum leak with smoke and all i can see is at the intake manifold there is a small nipple under what seems to be a temp sensor that goes into a bigger hole above it. When plugging that nipple on idle the cars STFT goes to -24% but leaving it as it was (open) its about 6%. So the question would be what could be causing no or little boost and weird stuck 1200rpm sometimes. Also is the pre cat o2 sensor a wideband sensor? As the post cat according to by obd2 scanner hovers 465mv - 750mv while the pre cat sensor hovers at 1500mv and has jumped regularly to 3000-5000mv. I cleaned the MAF sensor when i did the job with maf sensor spray by liqui molly and also that temp sensor in the intake manifold. The MAF seems fine according to my multimeter. Im at wits end cant really seem to diagnose the issue and there are no stored codes.
Old May 6, 2022 | 11:32 AM
It seems like theres an overfill small pipe by the windscreen wiper fluid tank that might go there on that nipple, what would be the point of that?
Nevermind it doesnt go into the wiper fluid tank it goes around it somewhere, that fixed the issue. Wonder what it is.
My car is reading -25% at idle on the STFT but not tripping any rich codes, LTFT at 4.6%. When driving STFT goes to more normal ranges, the car drives fine and has boost again after connected the small pipe, but what can cause rich STFT in idle? I'm still worried about 02 sensor 1 bank 1 which is pre cat giving readings of 1500mv at idle and jumping to 5000mv in some instances when driving.
MAF sensor reading 3.5g/s at idle is also seeming a bit high for a 1.8l engine unless it might be a bit wind but doubtful.
After checking values again today at idle STFT at -17% so went a bit down and the LTFT stays at 4.6% and am starting to worry why its not changing. Also noticed when turning the steering wheel in idle the STFT goes down to -7%. Im pretty much just relaying all things ive noticed so far.
Old May 7, 2022 | 09:22 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Just curious, do you know which engine model you have? In North America the C230 is a non supercharged V6 (M272) for 2006. For 2006-2007 the engine selection deviated quite a bit from the earlier years. Sounds like you have the M271 I4 engine but just want to verify.
Any CEL? If so, it would be prudent to post any codes here as well.
Not sure about the particular O2 sensor specifications for your car but my (rather poor) understanding is that they typically run in the 0-1V range. Unless there's something I don't know about for this car model, 5V sounds high.
Old May 7, 2022 | 10:44 AM
tkid's Avatar
C230K M271 CL203 2003 model
I have a 2003 c230K. For the O2 sensors, sensor 1 gives a voltage between 0-5V, and sensor 2 reads between 0- 1V..
Old May 7, 2022 | 11:52 AM
slammer111's Avatar
Thanks for posting the graphs. Learned something new. Also that would eliminate the O2 sensors as the culprit.
OP, did anyone (yourself or another mechanic) work on the intake side of the engine before these problems appeared? Did this problem simply appear one day? Any additional information here would be helpful. Also do you have a photo of the (nipple) sensor in the original post?
I assume there are no leaks in the intake system leading up to the throttle body. The hose between the silencer (in front of the serpentine belt) and the EGR is known to crack, though it probably won't result in a huge loss in intake pressure.
Old May 7, 2022 | 01:29 PM
Its M271 engine, well it has no CEL and its not running bad or anything I just noticed it when checking live data with OBD2. Smoke tested for vacuum leaks and nothing, also checked MAF sensor with multimeter and no issues. Its only at idle, I'm thinking maybe a wire short somewhere?
Old May 8, 2022 | 12:50 AM
slammer111's Avatar
I remember having some weird trim numbers (weird enough to trigger a CEL) once. Did you check all the vacuum lines at the top of the engine?
Old May 8, 2022 | 03:30 AM
I did when smoke tested and it seems there arent leaks, i might just replace those hoses anyway thanks for the info on that thread. Is it normal though for the STFT going down when turning the steering wheel?
Old May 10, 2022 | 05:22 AM
slammer111's Avatar
That is a weird problem to have. I'd imagine they're unrelated and coincidential.
Any luck on the search?
Old May 10, 2022 | 05:32 AM
No luck, car is not running bad and and the MPG is about 7.9L/100KM when driving long normally, in town its about 9.4L/100KM. Engine only 90000KM on. STFT seems very normal when driving and it did go from -17% to -14% with new spark plugs at idle, also spark plugs are healthy tan brown no Rich or Lean signs. It might be normal at idle but who knows. I did add Liqui Molly Injector Cleaner to tank after the service so that might have an effect will have to see when I refill again. The LTFT on Bank1 stays the same though with no change at all.
