All of my minor annoyances . . .
. . . were taken car of yesterday in my C230K. When I bought the car in March, a small hairline crack was apparent on a steering wheel button during the night when it is backlit. Also, the head adjustment release button simply did not work whatsoever. Also, the door handle was a little sticky. Well, after having to order the part for the steering wheel from Germany (US part number was the wrong color), all of the minor irritations were resolved. Hopefully, nothing will come up before the "A" service in about a year.
Best regards,
CP
Best regards,
CP
same here....
I just got my baby back yesterday finally.....
I had the following problems:
1. hairline crack in the button and they ordered 3times
, came with wrong color. fixed.![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
2. buzzing noize from the back of car. fixed.![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
3. center vent controller(blue dial) has not aligned properly after installation of CD-Changer. fixed.![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
4. water leaking from the driver side door seal. fixed.![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Nothing is major but .... you know what I mean......
![Mad](https://mbworld.org/forums/images/smilies/mad.gif)
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
Re: All of my minor annoyances . . .
Originally posted by chronopassion
. . . a small hairline crack was apparent on a steering wheel button during the night when it is backlit.
CP
CP
2008 VW GTI
Does anyone else think the feel of the turn signal is weird? I mean when moving the stalk up or down. Mine has a bit of a sticky feeling. It almost feels like there's a burr on one of the moving parts inside and that it needs to be "broken-in". I tried turning the signals on and off a few times to see if it would wear-in, but there's no change. It's not a big deal, but I expect a buttery-smooth feel like cruise control stalk. No?
my 2 cents..
2008 VW GTI
Fuzz, I know what you mean. The point where the stalk cliks into position is a little hard. It's more like a "snap!" instead of a clik like I'm used to. Anyway, I might mention it when it goes for service A and I'll try some others on the lot to compare.
2002 C240 6-spd (ret)
On mine, the movement to the point where it "clicks" is smooth, you know, where you move it to if you're just changing lanes. I would say the actual "click" into the full turn position is somewhat "soft", not a sharp click.
2008 VW GTI
Thanks Mark. I got a C230K sedan loaner before and the "click" was soft. I just figured it had 80K miles so it was must have been worn-in.
The movement on mine is smooth, but the "click" is a "SNAP!!". I think it even makes that noise...
