No power anywhere after dash out
Old May 28, 2022 | 02:32 PM
C230Komp0713's Avatar
2005 C230K, 2008 Sprinter
I'm changing the heater core and went through the process of removing the dash. I wanted to verify where its leaking and went to turn the car on, but there's no power anywhere. Checked all fuses, battery is ~13v....
There's no connection at the obdii port, no lights come on. I didn't remove any ECUs, any help is appreciated!
Old May 28, 2022 | 05:00 PM
Ok, i do have interior dome lights and the red light next to the shifter comes in when I put the key in.
PLEASE HELP
Old May 28, 2022 | 08:48 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
There's nothing attached to the upper dash other than the instrument cluster and the passenger side airbag.
Obviously something got disconnected. Make sure you understand how each connector clicks into place. Some may have a lever or a sliding lock.
You didn't touch the ECU connector?
Old May 29, 2022 | 01:04 AM
Nope, ecu connects at air filter under hood. I did disconnect and re seat the ecu cables AFTER I posted this and had nothing come on inside.
I did see moisture in the footwell. I'm thinking now something or somethings got wet and that's the culprit. Hopefully adding power didn't short anything out.
Thanks for the response
