Noise from kompresor?
Old Sep 12, 2022 | 09:23 PM
worster's Avatar
W203 C180 SPORTCOUPE M271
Hi guys, i have problem with my w203. What can it be? Thanks for help..
https://youtu.be/rep4ubJrpos
Old Sep 13, 2022 | 07:05 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Sounds like the purge valve which makes a ticking noise. Any other noises from the engine? Any CEL or error codes?
The other thing that comes to mind is the serpentine belt. Is it in good condition?
Old Sep 14, 2022 | 07:22 PM
worster's Avatar
Only P202C code.. So its propably serpentine belt. Yes?
Old Sep 14, 2022 | 08:53 PM
tkid's Avatar
C230K M271 CL203 2003 model
Try removing the top air intake pipe?.
The belt and pulleys are very close to a lot of pipes and hoses, could be something simple, just rubbing?.
It will be easier to see without that top hose in place.. and as it's a simple air pipe into the filter, you could start the car without it in place, and see if you can localise where the noise is coming from..?
Old Sep 14, 2022 | 08:59 PM
tkid's Avatar
P202C -001. CAN message from control module EIS ,: CAN signal interruption
In my case this code was due to a dirty window on the key! If you look at the end of the key, there is a little red plastic window; if dirt gets inside this window, it can cause CAN bus interference when you start the car..
There is a procedure to open up the key, which will allow you to clean the red window from the inside, and hopefully clear that code!..
Old Oct 31, 2022 | 02:51 AM
viviorunitia88's Avatar
c230k
I would check your ac compressor. When I thought I was getting noise from the supercharger it was the ac compressor. Shortly after the pulley decided to free itself and left me on the side of the road.
