Judder under braking from 35mph up, help
C320 CDI Avantgarde SE AMG Estate 2005 (55)
Hi I have looked around the forum before asking this, apologies if someone has already answered. I have an ongoing issue with my 2005 s203/w203 C320 CDI estate. It judders a bit under braking at higher speeds - due to this the discs and pads were replaced however it did not cure it. Following a very unwilling garage who eventually replaced the front discs and pads under warranty in addition to both front rear upper and lower control arms and drop links on the front, rear discs and pads and rear suspension bushes it seemed fine for about 500 miles. Now it is back and I am stuck as to what to do next to cure it. It went to another garage who took the discs off to check the hub was clean, check the wheel bearings and measure the run out on the discs (which came back fine) and still it judders.
My next step unless someone can guide me is to maybe change the inner and outer track rod ends and the suspension top mounts.
What else could it be? The judder is slight felt through the floor and steering wheel - any ideas?
Thanks in advance and apologies if this is covered elsewhere on this site
