Replace Air Filter
Old May 21, 2002 | 08:58 AM
shtatc's Avatar
2001 C240 6spd
Question Replace Air Filter
Has anyone replaced their own air filter? Not necessarily with aftermarket one. Tried doing a search...not thing really comes up. How difficult is it? At what intervals (mileage)? Is it worth changing on your own, or wait until the service schedules? I did my own dust filter for the climate control....seems like that needs to be changed at 10K. I am wondering if the air filters need to be changed at the same time also. Thanks.
Old May 21, 2002 | 11:26 AM
Mark08859's Avatar
2008 C300 Sport
If you're not going to an aftermarket air filter, wouldn't the standard filter be replaced at some point during a routine service?
Old May 21, 2002 | 12:00 PM
awiner's Avatar
2003 CL55 AMG
Not for Free it won't..
Old May 21, 2002 | 12:15 PM
Mark08859's Avatar
2008 C300 Sport
Ah haaaa. Guess I have some hard lessons in front of me as to how much "free" scheduled maintenance will cost.
Old May 21, 2002 | 03:08 PM
shtatc's Avatar
2001 C240 6spd
I might assume it may be covered during the Service B. But I think the filter needs to be changed before then. If it is done as part of the Service B, then it should be "free"..and I use that term "free" loosely...should it not?
I really do not want to spend $50 or more on labour on an item that I can install in a few minutes myself.
Took me less than 2 minutes to install the dust filter...the part cost $14. The air filter should not be that hard to do.
Old May 21, 2002 | 03:35 PM
mleskovar's Avatar
'17 Jaguar XF
Two air filters, easy to change. Pull up on the engine cover/airbox to remove. Eight torx screws to remove the two airbox covers. The service booklet lists the replacement cycle at '4 years or 60K miles'.
Old May 22, 2002 | 08:25 AM
shtatc's Avatar
2001 C240 6spd
mleskovar,
thanks for the info. with all the dust and crude in the air in AZ, I will probably need to change the filters a little sooner than the factory recommendations.
