W203 headlight upgrade
Then there are options if you want to modernize the look of your car. For example, the facelifted (MY2005-2007) halogens have the modern clear look, but can also fit the LED H7 bulbs. Or you can install the OEM bi-xenon HID headlights, which have the most modern look of the bunch, but these won't be LED.
Lastly, there are aftermarket options, but for those I'd be worried about headlight performance.
Will the lights flash like they do when you do Xenon upgrade without setting Xenon to present on the ECU?
( Due to lower power draw.)
