Mr.
all fuses and relays checked out. Got it started but stuck in park got it out of park drove it but it would not change gears. Code we got are P2030-4 CAN message from control module N15/5 (Electronic Selector Module (ESM/EWM)) or A80 (Intelligent Servo Module ISM) for direct select) is missing or faulty. Communication fault/ please refer to the CAN status in Freeze Frame Data (FFD) as well (P0600)
P2036 no or incorrect CAN message from the control mudul N47-5
p2037 No or incorrect CAN message from the control module N15/3 (Electronic Transmission Control (ETS/EGS)
I sincerely trust someone would be able to assist.
you have can node problems or maybe wiring.
to fix yourself, you need something to talk to car at higher level then scanner.
full on dealer system think it is called xentry
