Location of the Light Sensor?
Old Oct 31, 2004 | 07:36 PM
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
Where is the sensor that triggers the automatic headlights? I've been looking for where it is b/c there are really weird times/situations in which the headlights turn on/off and I was just trying to make sense of it. Particularly at dawn/dusk. Thanks!
Old Oct 31, 2004 | 08:04 PM
Phillip711's Avatar
05 C230
on the windshield, if you look in the upper middle part, you'll see sensors.
Old Oct 31, 2004 | 08:06 PM
nlpamg's Avatar
I thought that that was the rain sensor? Are they combined?
chibial's Avatar
i thought that was the rain sensor?
chibial's Avatar
dang you beat me to it nlpamg
hahaha
Old Oct 31, 2004 | 08:07 PM
nlpamg's Avatar
LOL, cool... Same timing. I feel like I need to say "jinx".
Old Oct 31, 2004 | 08:11 PM
chibial's Avatar
now say chibial times 10
Old Oct 31, 2004 | 08:31 PM
EKY's Avatar
EKY
2006 Acura RL - Aspec rims/spoiler, JDM grille
I thought it was that black thing on the hood? I also notice my headlights illuminate when the wipers are activated via the rain sensor. I notice the MB sensor is different from the one I had on my 3.5RL. It seems to "look ahead" if that makes sense. It won't illuminate under a bridge where my RL would. I find this feature neat. The RL would always turn on/off especially when going under all the freeway overpasses in traffic. The MB one won't turn on unless everywhere is dark and it even activates much quicker in tunnels... like it fore-see's the darkness ahead. Hope that makes sense. lol
Old Oct 31, 2004 | 08:47 PM
MB-JIM's Avatar
06 C 350 2014 GLK350
It's the small black dot on the rear view mirror. I block mine out with a piece of black tape
Old Oct 31, 2004 | 09:04 PM
EKY's Avatar
EKY
I think Phillip was right. I covered the center sensor on the bottom row and my lights came on. What is the sensor on the hood?
Old Oct 31, 2004 | 09:48 PM
Phillip711's Avatar
05 C230
they are light sensor and wiper sensor..
I worked for Mercedes for awhile.. * Training helped * =P
the little bubble dot on the hood is for the climate control if you put in the AUTO mode.
nlpamg's Avatar
That's for the auto-dimming mirrors.
Why would you block out the automatic lights function when you can just turn it off and use it manually?
Old Oct 31, 2004 | 09:49 PM
nlpamg's Avatar
cool, thanks!
what's the little black circular thing on the middle of the hood? I always thought that it was some sort of senor.
Old Oct 31, 2004 | 10:02 PM
Phillip711's Avatar
05 C230
its the sensor for the climate control..
Old Oct 31, 2004 | 10:20 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
On pre-2004 W/CL203 there were 3 light sensors: rain sensor (top of the windshield), then road-ahead light sensor (front side of the rear view mirror, faces forward) and ambient light sensor (imbedded in the mirror, faces rearwards). This has since been simplified by MB, and all news models have a combined rain and light sensor mounted at the top of the windshield.
Old Oct 31, 2004 | 10:22 PM
SUNILP's Avatar
2015 E250D
The sun sensor for c320 is on the hood. For climate control
Old Nov 1, 2004 | 08:10 AM
dgwee's Avatar
C180K
I have the 2005 and the "road-ahead" sensor (front side of the rear view mirror) is still there. Unless this senses something else in the 2005...
There is an orange coloured LED below the rear view mirror... Anyone knows what this is for?
Also, anyone knows how the rain sensors work (What do they sense? Moisture?)? It can't be because its behind the windscreen... Its also "intelligent" enough to know when the rain is heavy or light...
Old Nov 1, 2004 | 10:00 AM
Narcissus's Avatar
2001 C240 Tectite
The led on the mirror is for the garage door opener, you know it's in program mode if it's flashing... etc..
Old Nov 1, 2004 | 10:43 AM
SUNILP's Avatar
2015 E250D
The sensors actually sense water droplets and NOT moisture. There is a mirror with lens that is used and I believe it senses the difference is refraction of light. When water passes over it, light refracts differently. The LED that is Always ON is the new ambient light that illuminates the center console area. The led for the garage door opener is different. THe Ambient Light is a 2005 added feature. Do a search. Mirrors run around 700 bucks new before anyone asks if it can be retroftted.
Old Nov 1, 2004 | 11:40 AM
XRAYVSN's Avatar
2004 C320 pewter/charcoal
Does anyone know if you can adjust the sensitivity for the auto light function? I leave my lights on the auto function always. In the morning, even if it is bright out, it seems to turn on the headlights. It turns on appropriately when I drive home in the evening, but I think it's a bit sensitive for the morning (dawn light).
Old Nov 2, 2004 | 06:06 AM
dgwee's Avatar
C180K
I don't think its more sensitive in the mornings, rather, it takes a longer time to go off which you won't notice in the evenings. This is so for a good reason - you wouldn't want the headlights from an on-coming vehicle turning off your headlights while your car is moving...
Old Nov 2, 2004 | 06:14 AM
dgwee's Avatar
C180K
I found out (through experimenting with the rear view mirror's sensors) that the "road-ahead" light sensor actually doesn't switch on the headlights. Instead, it works together with the sensor on the mirror to auto-dim the rear view mirror.
If the light level at the front of the car (try covering the sensor with a card) is lower than the rear of the car, the mirror dims.
