02' C320 Revival
Main question is what to do next? I'm hoping the brakes/calipers are ok and are functional at least for a while once she turns over and runs. Oil change, and just drive it and see; thoughts?
Just give it a drive. Things should be fine.
From looking top-down, it's definitely most accessible from the bottom side. How difficult is the job, bolt access and a plug or two? I'm not familiar and don't want to bite off more than I can chew. All the other pulley spin/can be moved freely by hand, except the AC compressor.
I imagine a licensed mechanic has to drain the system first to capture the refrigerant. Not sure if it can be DIYed for this reason.
