Unknown wire that's been disconnected
Hi all,
i found this wire today sticking out from the bottom off the dash when i sat in my passenger seat for the very first time, is there anyone that might know what it might connect to? I'm assuming the previous owner had disconnected it in the past and forgot to plug it back in
Its got the stock raidio unit. But i took the radio out a few weeks ago and it did seem like someone took it out and put it back in without plugging it in properly, I didn't pat attention to any missing plugs so it could be from there. The radio turns off every 30 minutes and the steering wheel controls don't work, similar to what happens when you turn the radio on when there's no ignition on
C230K M271 CL203 2003 model
I think you found your answer!..
from memory there are a few plugs into the rear of the radio unit, my bet is someone has disconnected it, accidentally or on purpose?..
thank you for the help!
The wire found under the dash may indeed have been disconnected by the previous owner. Check your vehicle's manual or consult a mechanic to determine its purpose and safety.
Spoiler
