W203 C180k ECU and C200k Engine
Old Oct 25, 2023 | 01:29 AM
zubairsherwani's Avatar
W203 C180K
Question W203 C180k ECU and C200k Engine
hi everyone,
I bought a w203 C180K 2003 (Vin 203046, made in South Africa). I identified that the engine has been replaced by previous owner. Current engine number 271 940.... which is for C200 163hp. ECU part number is A 271 153 61 79, which is for C180K. Car is working fine and there is no issue.
While scanning from a scan tool, there is an option of variant coding in ECM module, which has an option to change the engine to 105kw, 120kw and 141kw. By changing this option to 120kw, would ecu configure itself for 163hp or i have to replace the ecu with c200 ecu? is there anything else which has to be changed?
Thanks.
Old Mar 14, 2025 | 12:23 PM
Crime272's Avatar
Question
Which tool did you use and how it looked like because i am interested too.
Thanks a lot,
Crime
Old Mar 15, 2025 | 08:22 AM
112233's Avatar
w203cl
All the 3 engines have the same ECU SIM4LKE
Old Mar 15, 2025 | 08:23 AM
Crime272's Avatar
Yeah i know that they have the same ecu but what about power?
Old Mar 15, 2025 | 10:04 AM
Crime272's Avatar
And so i can just change the power level with xentry ??
Because i searched and found that c200k and c180k have the same injectors and intercooler.
