Purge Valve issue
Old Aug 4, 2012 | 04:27 PM
Sir Laneo's Avatar
2002 C240
Purge Valve issue
So I noticed a ticking noise. I have confirmed its the purge valve. It ticks and when I put my finger on it, it feels like a fast heartbeat. I have a few questions. What do i need to do to fix this? Do i need to replace the Purge Valve Fuel Vapor Canister and/or Regeneration Valve Fuel Vapor Recovery? If so, where can i get a new updated one at? I saw that there is a "new designed", but have no clue where to purchase it at.
Is there another fix to this?
Thanks in advance to any answers/replies!
Old Aug 4, 2012 | 05:54 PM
phister's Avatar
06 C230 SS 6spd
go to rmeuropean or mymercedesparts and they should have the part
Old Aug 4, 2012 | 05:55 PM
Sir Laneo's Avatar
2002 C240
Do i need both pieces?
Old Aug 4, 2012 | 05:58 PM
phister's Avatar
06 C230 SS 6spd
usually in most cases its the canister. you can probably remove them and see if its just dirty and needs a cleaning.
Old Aug 4, 2012 | 06:02 PM
Sir Laneo's Avatar
2002 C240
Ah, well I'm not really mechanically inclined at all. So i wouldn't have a clue how to even do that, let alone put a new one in. I'm a newbie and attempting to learn.
Old Aug 4, 2012 | 07:51 PM
Glyn M Ruck's Avatar
Super Moderator
Replace it. The best way. See Wiki. You can't repair them.
Old Apr 10, 2015 | 09:19 AM
Dollos's Avatar
Mercedes C32
So the ticking noise is not good. What exactly does this guy do. I thought the ticking noise was normal. Whats happens when it ticks?
Old Apr 10, 2015 | 02:08 PM
cm60k's Avatar
Purge valve is an electrically-operated solenoid, that controls the amount of fuel vapor that is purged from the charcoal canister. it's controlled by the Engine ECU,,
When the engine is off, the purge valve is closed..
ZAYED,,
Old Mar 15, 2025 | 10:12 PM
ZAutobahn's Avatar
1995 E320 and a 2002 G500
I realize this is an older thread but something needs to be addressed here. It is totally normal for a purge valve to make a ticking noise. The reason it ticks is because it is constantly opening and closing to prevent large gulps of air from getting sucked into the intake manifold which would upset the A/F ratio and confuse the fuel mixture regulation system. If it ticks it is likely doing its job.
