Brand new battery drained in 4 days
Old Nov 19, 2023 | 11:19 PM
Jay11's Avatar
2003 Benz C240
2003 C240 95k miles
This is the second brand new battery from wally, drained after 4 days of install. The first one drained after 2 weeks. They exchanged it for a new one. This one drained as well. This car was hardly used for the last 2 years, but at storing it I serviced etc, then it just sat stored. It has a brand new battery, passed state inspection, but it has a battery drain problem as it drained in 4 days after install. I charged the battery and it read 13.1 volts, (later after battery tests it cranked just fine.)
To chase down the drain, I disconnected the -ve terminal and connected a test light as per this utube method
. The test light came on immediately. I went about disconnecting each fuse, to see the test light will dim but it stayed steady on. Bummer.
Next used a matsuyi multimeter. Amps reading didn't change nothing even turning on something like head lights, even though they didn't turn on. Multimeter was steady reading at 01.57A to 01.155a no matter if I turned on anything or not; maybe I don't know how to properly test this function with this multimeter. However, I was expecting at east the first method above to indicate something. Tonight I have disconnected seat modules for the night and see how that will affect battery by tomorrow. Any suggestions, ideas...???
Old Nov 20, 2023 | 11:47 PM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
Originally Posted by Jay11
2003 C240 95k miles
To chase down the drain, I disconnected the -ve terminal and connected a test light as per this utube method here. The test light came on immediately. I went about disconnecting each fuse, to see the test light will dim but it stayed steady on. Bummer.
Do you have electric memory seats?
https://mbworld.org/forums/c-class-w...c230-draw.html
Old Nov 21, 2023 | 12:29 AM
Jay11's Avatar
2003 Benz C240
Originally Posted by S70Houston
Yes. I thought by removing all fuses that will include the seats and therefore ID them as the problem source.
