Oil in spark plug cylinder/should i also use block sealer
Old Jan 27, 2024 | 01:44 PM
zzyyzzxx00's Avatar
2004 c230
I have a 2004 C230K, have oil in #1-3 & clearish liquid in #4 in the spark plug cylinders. Should i also add block sealer?
liquid n oil
clearish liquid in one cylinder. I am replacing the valve cover gasket, should i also use block sealer?
Old Jan 28, 2024 | 03:51 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
liquid n oil
clearish liquid in one cylinder. I am replacing the valve cover gasket, share seals uld i also use block sealer?
I don't know what that gunk is but there are seals inside the valve cover for each cylinder.
Old Jan 29, 2024 | 03:08 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Hopefully there aren't any cracks. Might want to just replace the valve cover seals (1 big one, 4 small ones).
With that said, that does look suspiciously like coolant. Hopefully that isn't a failed head gasket.
Old Jan 29, 2024 | 04:22 PM
zzyyzzxx00's Avatar
2004 c230
Ya my friend said it was radiator fluid
Old Jan 29, 2024 | 04:24 PM
zzyyzzxx00's Avatar
2004 c230
Yes going to replace gasket, TY
