Brake sensor values
Old Jan 30, 2024 | 05:13 PM
Gabe12's Avatar
2005 C230 Kompressor
Brake sensor values
Can anyone tell me what the range values should be on the brake pressur sensor and the booster diaphram travel sensor? On my brake pressure sensor without pressing the brake itfluctuates from .06 to.26 bar, then when I press the brake all the way down it shows 83.2 bat. Is that within range? And for the travel sensor it starts with no brake pedal at 3.3 inches and when brake pedal pressed all the way it shows 13 inches......that can't be right can it? The main problem I'm having is when I turn the key on my brake lights in back stay on as if I'm pressing the brakes and I'm not. It's a 2005 C230 Kompressor. Thanks in advance for any help.
