Floor shifter issues not going into park
Before replacing, I could drive for a couple days with no issues. Then have issues with the car not knowing where the shift lever was placed.
Symptoms were, car stuck in gear and not being able to shift from D to anything past N
It was super random. The piece that needs to be fixed is able to be removed... Just be warned that unless you remove the entire shaft, you run a high risk of damaging one or two tabs to the failed devices.
