Lights
Does anyone know why the w203 healights stay on all/most of the time after start up?
wheras most other mb's the light only comes on when you put it into drive!
can you change the selection?
thnx
Now, as to why they seem to be staying "almost all the time", do you mean they are on even when it is bright outside? I have noticed that the lights come on earlier than some other cars I've had with auto lights -- that may be a threshhold setting MB uses. I'm not sure, but perhaps this threshhold can be adjusted by the dealer. Or, maybe you are having a problem with the sensor that determines the ambient light level.
Of course, I am not sure if this is legal in Canada, I couldn't be bothered to change it. Anyway, I like the Xenons lighting the way all the time. Sure makes everyone move over to the right.
I don't think it is a problem of some sort, it's jsut that i am accustomed to the lights going of when i put the car in "park" or "neutral". like my ex-(202)
I also noticed that most car from the states have their lights completely off during the day! so do you guys have to turn the switch to auto or soemthing?
Bora: how does that module work?
phatbam: how is the ride of your 320 after installing the cup kit? and how much did it lower your car by?
thnx guys
I'm not to smart w/ cars!
But how does the cup kits work?
do you change the springs or the shocks?
from a pic i've seens before, it looks like a spring on a shocks like mcphersons on the front of a 203, but since the rear is like a mulitlink suspension, wut do you do? or am i talking about colilovers? not sure..
i may be wrong. but i'm jsut curious, becoz I want to lower my car too aswell as accomodating the best comfort.
how much the kit cost you?
thnx
I live in the US and am a strong believer in the DRL. Always used them on all cars I have owned.
the cup kit is a replacement of the factory shocks and springs, you get H&R shocks and H&R springs. the springs lower the car as the shocks are stiffer for better handling. i got a great deal on my kit, it was about 1100 USD installed with 4 wheel alignment.
btw,is DRL? Daytime running light??
so only the two lights under the high beam go on?
because in Canada, the headlights have to come on at all times.
