Air con not working
Old Jun 23, 2024 | 05:04 PM
VenomX's Avatar
W203 C240
Air con not working
Hi. Have a 2002 C240
The A/C OFF light is permanently Red which means the AC is not working.
I had a friend check my High/Low pipes and said the pressure was 30PSI and will get his tools to try and re-gas etc.
What is the most likely reason the A/C does not work ? All the fuses are fine, I have checked them.
Old Jun 24, 2024 | 04:15 AM
112233's Avatar
w203cl
Should work with 30 psi. If you have the comfort A/C you can read out more error codes, but I don't know how.
