U.S. vs. European Bi-Xenons
Old Nov 22, 2004 | 11:48 AM
jlm003's Avatar
2009 Porsche 911 Carrera S
Greetings and salutations to all...
Recently, I saw an ad in eBay for "European Version Bi-Xenons" wherein the seller claims that due to this fact these have much higher light/brightness output. I tried doing a search within the forum on this topic but nothing significant came up, hence this post.
Is there any veracity in this claim? If so, can anyone elaborate as to what is the difference in light output or bulb temperature between the two? Also, is there a difference in the light projection pattern?
Old Nov 22, 2004 | 12:29 PM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
Exclamation Light Projection Patterns:
don't know much about difference in light output or bulb temperature between the three (US, UK, Euro)... but here are the different light projection patterns, I posted a way back while ago:
______/ ______/ = US
\______ \______ = UK
______---- ______---- = Euro
US-spec pattern:
UK-spec pattern:
Euro-spec pattern:
Additional info, for the STFF impaired:
Originally Posted by MBenzNL
Euro spec and US spec bi xenon are both for cars with the steering wheel on the leftside...UK spec bi xenons (look into the projector and see wether it sais LV or RV in there) are for cars with the steering wheel on the rightside and will blind uncoming traffic when used in cars where people drive on the rightside of the road rather then on the leftside of the road...
and a link with tons of info...
BIXENON INSTALLED! Finally
Carlos
Saprissa@aol.com
Old Nov 22, 2004 | 01:20 PM
SUNILP's Avatar
2015 E250D
I am pretty sure all Xenon's are 35watts but the light pattern is different as shown above due to the different side of driving.
Old Nov 23, 2004 | 01:18 AM
I KOMPRZ's Avatar
2004 C230k (SOLD), 2005 C230k (Lease ended), 2004 Carrera 4 Cab, 2007 530i
I can tell you that right now, the brightness of the both, they are the same. I have the Euro spec Bix and my gf has OEM US spec, they light up the same except the pattern. The stock bulb 4300k is the brightess you can see visually, but I had to change it out to a 6000K. Now the color is much much (blueish) whitter, but I lost a little bit of visibility....but its ok, they are still bright enough.
Old Nov 23, 2004 | 09:39 AM
SUNILP's Avatar
2015 E250D
the color temperature rating is in kelvins. Stock is 4300K.A little more whiter 5000k. Then more towards blue is 6000K. Then after that you get purpleish but the light quality diminishes
