Air recirculation only works while selecting heat settings but not on cold settings
Old Jul 29, 2024 | 07:37 AM
Rihani's Avatar
Mercedes a207
I have a 2004 w203 .
i noticed that air recirculation works when i select heating but when i select cold settings and press the recirculation button.. the light on the button turns on but nothing happens...the flap doesn't work. I did an actuation test for the flap and it's fine.. i tried changing the controls whith another one.. and the problem stays the same..
anyone can help me figure it out
Old Jul 29, 2024 | 11:48 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
A bit of a long shot, but have you tried recalibrating the motors? Press and hold the (front) defrost and recirculation buttons until the yellow and orange lights start flashing. Give it a couple of minutes to cycle every motor, then turn off the ignition and wait another 2 minutes for the unit to lock in the calibration information.
The other possibility may be that there's something built into the controller logic, and that the system is actually working properly.
Old Jul 29, 2024 | 11:58 AM
Rihani's Avatar
Mercedes a207
I did the calibration method.. didn't work
Old Jul 29, 2024 | 12:09 PM
slammer111's Avatar
Which model car do you drive? Just realized you may be in the wrong forum too. Your profile says A207.
Old Jul 31, 2024 | 02:34 AM
Rihani's Avatar
Mercedes a207
I have two cars.. the one with the problem is 2004 w203 c200 kompressor
Old Dec 16, 2024 | 01:59 AM
Rihani's Avatar
Mercedes a207
I have the same problem. Did u manage to solve the problem.?
