C240 AC charging.
here’s the problem: I hook up to the low pressure service port and turn on the engine, and set the temp to max low. It blows cold air, so the compressor has to be running. When I activate the full valve on the gauge(trigger) the pressure drops but there is no flow from the Freon can. I’ve tried two different cans and two different gauge sets. One regulation, professional style set, and one of the type that you buy with a can at the auto parts store. For some reason, I can’t get any Freon into the system. Is there something I’m overlooking? I don’t need anyone to tell me I have a leak. If it takes several years to leak down just a bit, it’s more of a seep. Anyway, your input is solicited.
I was considering topping off the system myself in the future until I found this video:
That video and some other information I found suggest that it is best to have the system evacuated before adding refrigerant. I know that refrigerant recharge kits are commonly available, and that people use them with some success. I am not an expert on AC systems, but it seems possible that you are having the problem you describe because your system has air or moisture in it that is preventing you from adding more refrigerant.
I will be watching your thread to see if anyone else has suggestions. I would like to have my system repaired, but I have found that ignoring the guidance of my mechanic is usually unwise.
Oreily. I did mine in the winter so my defrost would work
and I had to warm the freon can in pot of hot water to get the pressure up.
THEN it finally kicked in a sucked in the Freon.
Oreily. /QUOTE]
I will check to see whether my local O'Reilly's lends this equipment to the DIY crowd. Thanks for the tip.
