C230K crank but no start with water damage
First I really appreciate anyone who reads this entire post. I have a 2005 C230 that has a crank no start issue. The car had been sitting for a couple of years because of the issue. I determined 2 years ago that the timing chain had failed. My sister never had it repaired and recently gave the car to my daughter. So Dad (me lol) had the head reworked and replace the timing chain. However the car still cranks but doesn't start. So I started my diagnosis process all over again. I found that the front Sam has water damage (visible corrosion) I have a used one coming, and that the drivers side floor was wet. So I pulled the seats and removed the carpet and inspected all the connections. I didn't see any significant corrosion. Here are the current DTC. Abnormal 5SRS - Supplemental Inflatable Restraint System9007 The Component Or The Signal Line To The Component S68/3(Driver-side Seat Belt Buckle Restraint Systems Switch) Has Short Circuit To Positive Or Open Circuit.9007 The Component Or The Signal Line To The Component S68/3(Driver-side Seat Belt Buckle Restraint Systems Switch) Has Short Circuit To Positive Or Open Circuit.900B The Component Or The Signal Line To The Component S68/4(Passenger-side Seat Belt Buckle Restraint Systems Switch) Has Short Circuit To Positive Or Open Circuit.907DFault In CAN Communication With Control Unit WSS.907C Fault In CAN Communication With Control Unit WSS.907E Fault In CAN Communication With Control Unit WSS. Abnormal 2SAM_F - Signal Acquisition And Actuation Module FrontB1029 Control Module AAC Is Not Sending Any Data. If Fault Code Occurs With No Complaint Reported And No Malfunctions, Erase Fault Memory And Perform A Function Check.B1030 Control Module UCP Is Not Sending Any Data. If Fault Code Occurs With No Complaint Reported And No Malfunctions, Erase Fault Memory And Perform A Function Check. Abnormal 7ESP - Electronic Stability ProgramC1210 Terminal 30 UndervoltageC1310 Check Power Supply Of Component A7/3m1(High Pressure And Return Pump).C1330 A7/7y1(BAS Solenoid Valve) : Electrical FaultC1201 A7/7s1(BAS Release Switch) : Electrical FaultC1022 CAN Communication With The Engine System Is Faulty.C1038 Engine Control Module Not Identified Or Incorrect Control ModuleC1024 CAN Communication With The Engine System Is Faulty. Abnormal 1IC - Instrument Cluster9115 Fault In CAN Communication With Control Unit N22(AAC [KLA] Control And Operating Unit). Ignore This Fault Code If No Other Complaints Exist. Abnormal 2ESM - Electronic Selector ModuleP2000 The Braking Torque Value Sent From The Traction System Via The CAN Bus Is Implausible.P2010 The Braking Signal Sent From The Traction System Via The CAN Bus Is Implausible. Abnormal 2OCP - Overhead Control PanelB10D7 Fault In CAN Communication With Control Unit AAC.B1066 Roof System Is Not Normalized. Abnormal 3REAR SAM - Rear Signal Acquisition And Actuation ModuleB1091 Fault In CAN Communication With Control Unit N22/7(Comfort AAC Pushbutton Control module). If Fault Code Occurs With No Complaint Reported And No Malfunctions, Erase Fault Memory And Perform A Function Check.B1096 Fault In CAN Communication With Control Unit N72/1(Upper Control Panel Control Unit). If Fault Code Occurs With No Complaint Reported And No Malfunctions, Erase Fault Memory And Perform A Function Check.B1078 Fault In Communication With Component H3/1(Alarm Signal Siren With Additional Battery) Or There Is A Cable Fault.
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
You need to get this car onto a Star Computer at the dealer. Too many faults to make a sensible diagnosis without doing that.
Kind Regards,
Glyn
Kind Regards,
Glyn
outdoorjunke (03-14-2024)
