2002 C230 Kompressor coupe W203 actuator
Old Aug 11, 2024 | 02:06 AM
Jw40's Avatar
2007 ML500 4 matic W164.175
Good day,
My supercharger is not working. I tried resetting the flap as shown in other videos but no luck. I tried getting a reading on the actuator plug with no joy. we traced the wiring harness and found the same type of plug on top near the MAF and when we plugged the power in, the actuator flap moved. My question now is, do I replace the wiring harness or is there another unit that provides power to the actuator that work works with the supercharger.
Old Aug 11, 2024 | 07:24 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W203 forum...
Old Aug 12, 2024 | 03:05 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
A lot of factors determine whether your car will allow boost.
If you think there's a problem with the wiring check the voltage at the connector.
See attachment. I replaced my "recirculating air flap" twice and each time it worked
for a while and quit. Upon replacing my MAF with a NOS Siemens MAF from 2002
everything starting working perfectly. Of course check your codes, it will tell you
if the MAF is giving trouble. You can start by cleaning it with MAF cleaner.
I'm assuming you've checked your codes. No? Post them.
The flap not kicking in is 'limp' mode so if there's a vacuum leak or some
other issue it won't kick in and no voltage, get it? Check your hoses etc.
File Type: pdf
