Drive Shaft Carrier Bearing Relacement
Alfa uses the flex disc / guibo joint too. I’ve heard the key to replacing just one flex disc is marking the orientation of both ends of the shaft prior to removal and reassembling clocked exactly the same
Apparently this ensures the balance continuity previously set to the drive train. I’ve been told if this isn’t done then the entire unit must be replaced.
Check those exhaust system rubber hangers. They may make aftermarket ones with a small bracelet made of chain embedded inside the rubber hanger to double its life.
"Good morning Glenn, Fred has the following notes for your review: PERFORM TEST DRIVE CONFIRM NOISE. LIFT VEHICLE, LOWER EXHAUST SHIELDING TO INSPECT DRIVE SHAFT CENTER SUPPORT AREA, FOUND PROTECTIVE DUST BOOT DETERIORATED, SLINGING AGAINST THE BODY OF THE CAR. REMOVED REMNANTS OF BOOT, TEST DRIVE FIND NOISE ABATED. NEEDS TO HAVE DRIVE SHAFT DISASSEMBLED AND INSTALL NEW PROTECTIVE BOOT. ESTIMATE $570 INCLUDING DIAGNOSIS, LABOR, PART, TAX.”
Thank you
