searching for a part
Old Nov 14, 2024 | 12:29 PM
an6dk's Avatar
2002 mercedes c230 kompressor coupe (CL203)
I in my infinite wisdom have snapped off the brake bleed screw on my 2002 c230 k on the front right caliper. It didnt loosen at all so thankfully the brakes still work. I have the tools to get it out but I dont want to do so until i have a replacement screw. I havent been able to find this particular part anywhere and am wondering if other c class bleeder screws will work for my car. It has the base model brake calipers if that matters. appreciate any advice!
Old Nov 14, 2024 | 01:51 PM
112233's Avatar
w203cl
You can buy them from Rockauto
In general they are not Mercedes specific, I guess the caliper is from Lucas/TRW or ATE.
Old Nov 14, 2024 | 08:48 PM
Petethepug's Avatar
90 VW Corrado g60, 07 New Beetle Vert triple white & 09 Escalade ESV Plat LOL!
I hate it when that happens. I’d clamp the brake line …
Undo and remove the caliper to extract the offending bleed screw and (this time) buy an OEM or MBZ fitting sized as 100% for sure in your hands.
That’s assuming you’ve got a stealership or parts house nearby. I ordered some off RockAuto for the BBK on my caddy. They were plated on the threads. Uh, NO! Those did not get installed in the Brembo 6 pots.
Old Nov 14, 2024 | 09:59 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Replace with AMG calipers....
Worst case senario, find a used caliper for cheap.
Picknpull nearby? Small parts like that go for almost nothing...
or nothing at all..
Old Nov 15, 2024 | 03:59 AM
112233's Avatar
w203cl
FYI: Make a tool out of an old brake hose. Cut it, put some hot glue inside and use it as a perfect end cap.
Old Nov 19, 2024 | 09:00 AM
an6dk's Avatar
not a bad idea, might have to use that one in the future
Old Nov 19, 2024 | 09:04 AM
an6dk's Avatar
or nothing at all..
how much should the amg calipers be? would i need to also replace the discs and the pads? ive been wanting to get the amg calipers but am unsure of which ones I need and also whether i need to replace just the calipers or the whole caliper pad disc assembly, in which case id wait until my pads are gone. And yes I know of a picknpull that has a 2002 c230 in my cars color and trim actually (a pretty golden find i know) its just a bit of a drive so if I go that route Ill have to make a list so Im not driving 130 miles just for the screw
Old Nov 19, 2024 | 09:17 AM
an6dk's Avatar
thanks for the tip! i found them and they werent expensive.
