What ECU number fits
Old Dec 1, 2024 | 06:50 AM
nedimt's Avatar
c200 w203
Hello,
I have C200 W203 2.2 75kw diesel 2005y, my ECU needs replacement, how can I find out what other numbers also fit for my car?
Number on ECU is A6461500779
Old Dec 1, 2024 | 07:52 AM
trigital's Avatar
W213 All-terrain
Although a deep diagnose is mandatory before spending on a new ECU, you should know that a new ECU will need cloning or complicated programming for enabling for your car.
Choosing another reference number is VIN dependent.
Old Dec 1, 2024 | 12:56 PM
nedimt's Avatar
c200 w203
Hello, thanks for reply
VIN number is WDB2032071F617129
Old Dec 1, 2024 | 01:09 PM
trigital's Avatar
W213 All-terrain
Any of those codes,
Old Dec 1, 2024 | 03:00 PM
nedimt's Avatar
c200 w203
Any of those codes,
Hello, thanks again.
Just these four or there is more... I am asking because its really hard to find ECU with those numbers
Old Dec 1, 2024 | 03:26 PM
trigital's Avatar
W213 All-terrain
No .more options in EPC.
If you can clone the SW, you can get the HW number from yours and find any part number with the same HW number.
Are you sure that your ECU needs to be replaced?
Old Dec 1, 2024 | 03:57 PM
nedimt's Avatar
c200 w203
Pretty sure, 3 mechanics checked it.
Ok, thanks mate
Old Dec 1, 2024 | 04:02 PM
trigital's Avatar
W213 All-terrain
Ok, thanks mate
Did you tried a proper diagnosis with Star/Xentry?
Also, I hope "mechanics" is generic, as a electric technician will be more useful.
This ECU usually has a problem with activating the circuit 87, very easy to fix.
Here on forum, even at one of my replays there is some guys who repair it.
Old Dec 8, 2024 | 02:02 AM
nedimt's Avatar
c200 w203
Hello, I found this yesterday on yt and tried it and it works.. also the guy im comments says that its faulty ECU
[​​​QUOTE=trigital;9073460]Did you tried a proper diagnosis with Star/Xentry?
Here on forum, even at one of my replays there is some guys who repair it.[/QUOTE]
Old Dec 8, 2024 | 03:08 AM
trigital's Avatar
W213 All-terrain
https://youtu.be/MyBE5BKk1O0?si=PJZnjKUDAA6DggqN
That's the "Circuit 87" from my post,
15 min job for repair.
ECU provide negative feed to the relay and you can follow the circuit till the pin from driver inside the ECU. You can try resolder that part of the driver.
