Bad rear SAM?
But, I had installed two rear SAM in my ownership time. Both were purchased on eBay with good results (the one lasted about 80k before the third). That said, the new "old" SAM's are all getting up there in age and your results may vary.
Hello Moto, I work for MBUSA and would like to help you if you are still struggling with making the "new" Rear Sam functional. The bad fuel pump info you are referring to is a wiring issue not a coding.
Each module is coded for the vehicle via the Developmental data screen in SDS. You do not need to worry about not being able to correct or change the "info". By knowing what options are listed under your vehicles VIN we can change the wrong options to the right ones under the developmental data menu in the rear sam module.
Message me if you still need coding.
