W203 M272 2.5 Swap to 3.5
Old Jan 25, 2025 | 04:15 AM
Lordair50's Avatar
W203
Hi,
I would like to asking how to solve some problem of my car due to I got P2279 Code ( Check intake tract for unmetered air.) and my vehicle run not smooth. I have been swap engine from M272 displacement from 2.5 to 3.5 due to my 2.5 freak out. I have been selected M272.964 from W211 with no Vacuum Pump at the back and install to my W203 with the same ECU From M272.920 (2.5) and tuning ECU. I have swap only engine and use the same Transmission and Rear Differential.
I have done in that way because in my country M272.960 (3.5 from CLK or W203) is no longer available and not easy to find, so that why I choose this way. After I have swap the engine I have run into that problem P2279 code which I think the problem might be No Vacuum Pump and the ECU Version that equipped with Vacuum Pump. I have been checking for intake manifold leak, vacuum hose, and replace a MAP Sensor and it still happen.
So, the question is can it be coding a vacuum pump to off in my ME9.7 ECU.
Can anyone suggest how to solve ?
Thankyou
Old Jan 26, 2025 | 06:32 AM
Lordair50's Avatar
W203
Of course no sir, I use all the control module from 2.5. Can it be only swap the TCM from 722.906 to 722.998 and ECU or do I have to swap all of the transmission to 722.906 ?
