Bigger injector installation on m111 engine
Old Today | 07:50 AM
  #51
ziigen's Avatar
2001 W203 C200 Kompressor
Originally Posted by 2002 m111 c230
https://www.siliconeintakes.com/fron...ger-p-207.htmlHey brother, I can help you with the intercooler. I did all the work myself. I'll send you the link from silicone intakes website. I did lots of research and ran into a lot of forums saying that a bigger intercooler (TOO BIG) would rob the power/pressure, BUT I found a much better perfect size that won't heat soak. Renntech made one years ago and it didn't reach the numbers people were hoping for. This one is slightly smaller than that and between the size of the stock and renntech but a little more towards the renntech size. https://www.siliconeintakes.com/fron...ger-p-207.html so the stock size is 25 inches I believe but the height is taller and the width is wider on the bigger one. It helps A LOT more than the stock one. I was so happy when I first drove it! Unfortunately I don't remember how many bends of the silicone couplers and pipes I had to buy and all.
Funny enough, its not pretty but if you retain the stock clip-in style intercooler flex hoses, a 2.5" silicone elbow slides over and locks onto the end of the boost pipe with a hose clamp very well, seems to be holding my lil sub 10 psi and well it was as easy as just finding the best mounting location for the ic and putting on the hoses. IATs are wayyy down compared to the stock one, and this IC isnt so much bigger its just aluminum. No noticeable difference in pressure drop across the ic as well.
