w203 randomly ****s off out of nowhere
Old Mar 1, 2026 | 09:36 AM
plebeus89's Avatar
2001 w203
Exclamation w203 randomly ****s off out of nowhere
hi I have a 2001 mercedes-benz w203 c200. its not a compressor engine, nor a cdi. its a euro spec c class. I have this random problem where While driving, it randomly, out of nowhere shuts off the gauge cluster, the horn, wipers, AC, the turn signals and prevents from rolling down the windows. I have looked everywhere, other forums, youtube, reddit, even asked actual mechanics around my area but they all said that in order to diagnose it, I have to bring it in while that issue is present, otherwise they cant do anything about it. with the research I have done by myself I came to the conclusion that its either a wiring problem or it has something to do with fuses. I would be glad if any one of you could help me out with this, big or small. thanks in advance
Old Mar 1, 2026 | 12:55 PM
smiles201's Avatar
2023 E 450 Sedan. 2018 GLC 300. 2013 E 350 Coupe (retired)
Out of almost total ignorance, I would check that the battery is making good ground connections, that the connections are tight and free of corrosion.
Old Mar 1, 2026 | 02:43 PM
plebeus89's Avatar
2001 w203
well I usually keep it clean, I even swap the exact same battery into other cars as well, back and forth. plus usually it starts up just fine, its while DRIVING that it does that, (but very very rarely).
Old Mar 1, 2026 | 02:54 PM
smgak's Avatar
C230K
Maybe the front SAM is at fault.
Old Mar 2, 2026 | 09:05 PM
tkid's Avatar
C230K M271 CL203 2003 model
Front SAM?, or behind the gauge cluster there is a big cable that clamps into the rear of the gauge cluster.. I had a similar issue that was caused by this cable being slightly misaligned.. unclamping and re-clamping eventually got it to connect correctly.. good luck!
Old Mar 5, 2026 | 04:16 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Why is the title X'd out?
"randomly ****s off "
Is it shutting off or something
one can't say in a forum?
Old Mar 5, 2026 | 04:58 PM
smgak's Avatar
C230K
He probably meant to write "shuts", but missed the letter u on the keyboard.
this error in the title makes a lot of sense contextually though
Old Mar 6, 2026 | 04:51 AM
plebeus89's Avatar
2001 w203
yeah sorry for that Its meant to say "shuts off", I don't know why it happened
Old Mar 6, 2026 | 04:52 AM
plebeus89's Avatar
2001 w203
sorry I wasn't able to reply sooner, thanks for the advice I'll definitely take a look.
Old Apr 18, 2026 | 11:05 AM
Jessgarcia's Avatar
2006 Mercedes Benz C230 sport w203 Mars red
Similar prob/solution
I have a 2006 c230 and I have had the same problem,or sounds similar, and it took me about 6months to figure out and fix .my problem was my ECU circuits and circuit board affected by years of that heat exposure on top of motor area and basically I had to buy a used one and have it reprogrammed.it cost me around $400.
Hope this helps
