Vibration in steering fixed
Well, I had since purchased a new pair of Michelin Pilot Sport tires, which did not fix the problem (although the vibration did subside). As for the "warped" rotors, I was going to replace them with x-drilled StopTech OEM-size rotors and a set of Mintex pads (none of which has arrived yet).
Long story short: the car recently went in for the front turn signal socket & harness update (warranty issue, fixed per MB TSB). While at it, I also requested full alignment (after recently installed springs settled properly). On the 2-nd day I was notified by the SA that there are problems in the front suspension. Turned out it was "thrust arm bushings cracked and leaking" (fixed).
Now both issues mentioned above are completely gone. The ride is smooth at any speed; no more brake vibration.
For those who don't know - many streets in DC are in horrible condition, with lots of potholes and poorly applied patches.I had a thought trying to figure out why they are out so early - maybe high tire pressure had something to do with it (I run 32F / 36R)? I also have AMG sway bars, but those can hardly be blamed - maybe only in combination with the first two factors. Still strange - unless it turns out to be a common problem.
On a complete side note, if you are getting that warped rotor feeling, it may not be warped rotors. It could be uneven pad deposits on the rotor. This happens anytime the pads are heated up enough and an extra layer of pad material is left on rotor when the car comes to a complete stop.
On a complete side note, if you are getting that warped rotor feeling, it may not be warped rotors. It could be uneven pad deposits on the rotor. This happens anytime the pads are heated up enough and an extra layer of pad material is left on rotor when the car comes to a complete stop. See this link for more details http://www.stoptech.com/faq/data/faq25.htm
I got a Roadforce balance done on the wheels, (and rotated my tires to make sure it wasn't a bad tire) which helped with the vibration, but didn't get rid of it completely. Then I got a 4 wheel alignment, replaced tie rods and sway bar links, and had the whole suspension checked out. This still didn't get rid of the vibration. I also noticed that my tire's started "cupping" from uneven wear, which was strange given I just got an alignment and Roadforce balance done.
I didn't think it made sense that warped rotors would cause vibration while driving. My car is going back to my mechanic Friday, and hopefully it's the thrust arm bushings that are causing this problem, because driving my car on the highway right now is irritating with the vibration! Will update status on Friday!
https://mbworld.org/forums/showthrea...t=leak+bushing
Bad lower control arm bushing will cause cupping.
