Wheel/tire question
After hitting a large piece of road trash, I had my car towed to Calstar Benz to have it fixed. Two wheels were bent, two tires blown, plus assorted damage to suspension parts. Service rep says that there have to be four good tires and four good wheels on it before they can begin proper diagnosis of suspension damage. Ok, I'll believe that.
Since I had to get at least two new wheels, I figured I might as well upgrade to 17 inchers. I called TireRack and ordered four 17x7.5 Superturismo GTs by O.Z. and four 225/45-17 Kumhos. TireRack promised me that they could be delivered on time - mounted, balanced, and ready to be bolted on.
Well, between TireRack and UPS they somehow didn't make it as promised ( FWIW, TireRack did offer to refund most of the shipping ) Only two of the four arrived. Sales rep says they can't fix it yet.
I told him to put the two good stock 16s -wth lots of tread left, BTW - on the front and the two new 17s on the rear. He said that his tech person told him that it won't work; they need all four to start repairs.
Am I missing something here? Or is it BS?
If not expect a major fuss by the dealer.
If youre still looking for wheels, MBKlasse usually has a lot of rims for sale. THe C7 rims are still my favorite rim for the Coupe if youre going with 17's.
There is no way that the ESP system can be looking for differences that small. A difference of 0.4% is within the limits of tread wear. It may even be less than the manufacturer's quality control tolerance. It is probably even smaller than the difference caused by a few pounds of air pressure. The ESP would be going off all the time if it were that sensitive.
2) Which 2 wheels were bent (see 1)? That could be where your stealer is coming from.
3) Ask him to explain the difference in regards to SS models: 24.7 (R = 245/40-17) & 25 (F = 225/45-17) when compared to std 16" = 24.9 (205/55-16). The figures were derived using std math and not taking tirespecs into account. Actually there is more to it as shown by this link. I don't have the english version for it.
HTH
HTH
1+2: It was all on the right side.
3: What is "SS" ?
But is there some other possibility aside from tire sizes?
Let us know if the dealers technician has problems with alignment.
There have been several posts of dealers not being able to align using after market rims without the alignment holes. With your front end damage they have to go with full factory specs.
As soon as my rear tires are gone, I am going to the 255/40/17 tires. At 25.0 inches it is closer to the front 24.9 than the 245's at 24.7 inches. But at least half an inch more tread width than the 245s and over an inch more than the fronts which really makes the staggered wheels look better.
3: What is "SS" ?
SS = Sport Sedan
In MY05 they use the same tire setup as the C32.
@breastroker
You might want to click the link. Some of the numbers provided will surprise you. Especially since it goes more in depth than just a static diameter. That might help explain a little further the tire size choice made by MB.
Then Mercedes switched to the "Mustang" 5 spoke wheels, also in the staggered configuration. I had the standard C7, the rear 8.5 rims were over $360 each. So I purchased a set of the "Mustang" 5 spoke wheels and had them polished so they look like chrome. They show off the AMG Brembo brakes better :p
Most dealers have these as take offs at decent prices, and there is always someone selling these, or C32 or C55 wheels and tires.
In the Tirerack web site, just click on the specs for any tire, it will list every dimension of all sizes of the brand. As agressive as these 255's look, they are Michelin Pilot Sports. The Bridgestone Potenza PO-3 is almost an half inch wider tread.
