Tranny fluid?
Originally Posted by Petmerctech
Yes, all newer MBs use synthetic transmission fluid.
outside. After it warms up, the shifts are smoother. My ride as 43k on it
and I'm thinking of changing fluid.
2005 C320 4Matic
This is interesting. This morning at 16 degrees F, my 05 wasn't shifting smoothly. RPMs went higher than usual shifting from first to second to third. When the car warmed up, it was smooth again.
2015 E250D
whenever the temperature is low, it is normal for the car to shift at higher rpm's to bring the CAT temperature up faster to eliminate pollution. Do a search on this forum as it was discussed earlier.
Originally Posted by trbo2nr
Newer = what years? Mine is shifting hard when cold and it's 17 degrees
