Interior Xenon Lighting Kit
Old Jan 23, 2005 | 07:54 PM
inFiniTE LooP's Avatar
2005 Volvo S40 T5 AWD, 2004.5 C230 Sport Sedan, 2005 E320 CDI, 2008 C300 4-Matic Luxury
i did a quick search and found no results, just wondering if any of you guys have these or heard anything good/bad about them???
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
i've already ordered them, which i guess i should have waited to do until i got some feedback from you guys , but oh well, if they suck that bad they weren't all that expensive anyway...
Old Jan 23, 2005 | 10:07 PM
sacguy's Avatar
11 W212 E350 Sport, sold 06 W211 E350
Hmm, never heard of interior xenon's before. The only drawback I can think of is that they may be too bright, but I liked the photos on ebay of the white lite and for only $39.99, you really cant' go to wrong.
Old Jan 23, 2005 | 10:16 PM
RunInColorado's Avatar
2007 CLK350 Sport, 2006 E320 CDI, 1978 Cessna 152
Seems like they are just "charged" bulbs, not true xenons with ballast and everything. Sounds like its somewhat like the xenon charged headlights. I would say if you like the look, go for it. Just make sure the wattage is right so you dont burn through a wiring harness or anything.
Old Jan 23, 2005 | 11:38 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
One has to be a major league moron to use HID for interior lighting. Well... Unless he has sunglasses welded to his ears and is 70+ years of age.
Old Jan 24, 2005 | 04:41 AM
smartjay28's Avatar
w203,ka7,e39
my guess is, its def out of the wattage range. to produce that 'whiteness' it might need a higher wattage. but who knows.
Old Jan 24, 2005 | 10:58 AM
kompressor boy's Avatar
offered here.......
the thought passed my for like a minute, than i said no, and even the owner of www.umnitza.com didnt personally like it, he has them available as well. Let us know how it turns out.
Old Jan 24, 2005 | 03:13 PM
Outland's Avatar
2002 C230 Coupe(M111)
The superwhite LED bulbs are as close as youre going to get to HID's for the interior.
Old Jan 24, 2005 | 03:22 PM
rockintunes23's Avatar
From: Delaware, United States. (First ~little~ state)
Mercedes-Benz
You can just change the light bulbs to xenon looking ones for about 10 bucks.
Old Jan 24, 2005 | 03:42 PM
thanks for all of your responses, all this talk about the wattage got me worried so i asked the seller about it:
I’m curious though, how many watts are these bulbs and do you know if they are the same watts as the bulbs they are replacing? Thanks~!
his response:
Our Xenon bulbs are specially designed for interior use. The Xenon bulbs generate a greater deal of heat than standard incandescent bulbs, so they are designed at 5W. You will notice a cooler, cleaner look with Xenon in your car.
so how many watts are ours? and do guys think this will cause problems? thanks~!
Old Jan 24, 2005 | 04:14 PM
rubensans's Avatar
Brabus K3
I think someone has to get them and tell us his impresions.
Best Regards.
Old Jan 24, 2005 | 04:38 PM
Could it be printed on the bulbs you want to replace? I know some are. Off the top of my head I dont know the wattage for the interior lights. The only other thing I could think of is if they are alot hotter than the stock bulbs, and its close to some type of plastic I would assume some type of melting might occur (again this is just a guess, not founded on any solid evidence).
Normally sellers also provide pictures of the bulbs themselves (all the headlight bulbs etc...). I wonder if he is going to sell you some type of bulb that is similar to the "SilverStars" sold at walmart etc for the HID look. Another reason I am going with this idea is the bulbs give off higher heat. Using more wattage and/or more tinting to cause color the bulb has (even a light color) the warmer the bulb will get. Thats just my opinion though and like anyone, I could be wrong.
If you do a search on the web for Xenon charged
http://www.google.com/search?hl=en&i...+charged+lamps
They are merely colored lamps, not true HID lighting (ballast, etc). So the brightness that results from HID will not be there, just the color. I hope that helps some! Good luck!
Old Jan 24, 2005 | 11:50 PM
MBC230k's Avatar
2005 C230K SS Desert Silver
They may not be true Xenon bulbs...
It's hard to tell based on the pictures given, but the light output does not seem any greater. It seems to me that only the color of the light has changed. The light is more white with the supposed Xenon bulb.
In fact, they may not be Xenon bulbs at all. Some bulb manufacturers are using neodymium in the glass that encloses the filament. The neodymium filters out the yellow spectrum...
Here is a snippet from GE's web page on their Reveal line of bulbs for the home.
What makes GE Reveal bulbs different?
GE Reveal bulbs make colors "pop" in a way they don't with standard incandescent bulbs.
Why? The rare earth element neodymium that's in the glass. (It's what gives these bulbs their distinctive blue color when unlit.) When these bulbs are lit, the neodymium provides a pure, clean light by filtering out much of the dulling yellow cast common from ordinary light bulbs.
GE Reveal bulbs come in both frosted and clear glass. I use both but prefer the clear. The glass on the clear bulbs still have a blue/purple tint when unlit. They work as promised. The light is much whiter and more pleasing to the eye.
Old Jan 24, 2005 | 11:55 PM
AaronC's Avatar
C32
I ordered a set. I will give them a review once they come in.
Old Jan 25, 2005 | 12:53 AM
I KOMPRZ's Avatar
2004 C230k (SOLD), 2005 C230k (Lease ended), 2004 Carrera 4 Cab, 2007 530i
Thanks for doing so....its really hard to judge by looking at the pics. Besides I think those pics posted were all photoshopped. I really dont know how well it will turn out, I hope they are just not like those cheap ones that were painted blue over the lense and will fade away over time. Let us know how it turns out.
Old Jan 25, 2005 | 01:14 AM
c230kracer's Avatar
cl203 Sports Coupe
Regular VS. White
Ok well, to get the real WHITE color look you would need LED Ones which i do have and when i put them in for the dome light....its white, really nice white but the bad things is...it does turn off completely....when i open the door my interior is all white but when i lock my door the Lights "should" have gone out but no...it stays really dim white and never turns off..I've also tried the regular bulbs with the blue tint like the Halogen bulbs, the color was not as white but was good enough compared to the original, the bad thing is...White color lights dont produce as much Lighting as the normal yellow lights do...they are weaker and you dont get as much visible light in ur car as with the normal bulbs...just letting you guys know my experience...i ended up putting back the normal lights...they are way brighter for me to actually look for things..
PS. those "xenon" powered blah is all BS its just a slight blue tint on the bulbs....really cheap shouldn't be paying so much...
Old Jan 25, 2005 | 01:15 AM
c230kracer's Avatar
cl203 Sports Coupe
I will post pics as soon as i take them for u guys
Old Jan 25, 2005 | 02:24 AM
so you use these GE Reveal bulbs in your car? do they make all sizes to replace all interior lights in the car as well as the license plate lights? i've purchased their 'normal' bulbs at the store before just for lamps and ceiling lights, but wasn't aware they made them for cars as well, perhaps i should invest in these as well and do a comparison between them and the 'charged xenons' i ordered
Old Jan 25, 2005 | 03:15 PM
MBC230k's Avatar
No, I don't use GE Reveal bulbs in my car. GE does not make any that fit any car that I know of. Sorry for the confusion.
I needed a web site the explained how neodymium was being used in bulbs. The GE web site was the only one I could find that had a decent explaination and I have personally used the bulbs in my house...
Old Jan 28, 2005 | 07:09 PM
gaiex's Avatar
'13 E500 Coupe AMG// '17 E350d // '24 E53 AMG
I have a 05' A6 v6 3.0TDI and it have blue ligths or leds, I don't know, in the foot area and in the doors!!!
It would be great to put something similiar in my sport coupe.
Attached Thumbnails Interior Xenon Lighting Kit-dsc04799.jpg   Interior Xenon Lighting Kit-dsc04798.jpg
Old Feb 6, 2005 | 11:27 AM
rubensans's Avatar
Brabus K3
Anyone has received them?
Old Feb 6, 2005 | 12:44 PM
i got mine last week but have been having some problems with them
https://mbworld.org/forums/c-class-w203/96998-interior-lights-where-all-em.html
https://mbworld.org/forums/c-class-w203/97323-replacing-map-vanity-lights.html
Old Feb 6, 2005 | 12:55 PM
rubensans's Avatar
Brabus K3
The ones that you manage to replace how do they look?
Can you post some pics ?
Best Regards.
Old Feb 6, 2005 | 02:49 PM
rubensans's Avatar
Brabus K3
I went to the car to get some data.
The reading lights are imposible for me to take them out.
Then:
Front Dome + Rear Dome + Tunk Light have: 10W K5618-n4o 42-->44mm
Glove Box + Traffic Plate lights have: 5W C5W 3.7-->3.9mm
The glove box light is a little dificult to remove; you have to open the side of the glove box and then pull + push the entire light.
Best Regards,
Ruben.
Old Feb 6, 2005 | 08:33 PM
thanks a lot for the help rubensans , while i was able to take off the side of the glovebox and i could see the physical light bulb itself, i couldn't manage to get it out or reach it, the space to fit your hand/fingers seems to small and i dont know which parts in there actually move , as for pictures, i took a few but it's a little difficult to tell anything, here are the pics. anyhow
these are the bulbs themselves
here is a picture of the light shining from one of the under door puddle lights
this is the original puddle light hanging out
this is the new installed puddle light
i tried taking pictures of the light shining from the rear dome light but all the pictures i took seem to be too dark, it really is much darker than the OEM bulb that was back there, although there is still plenty of light to see things when it's on. anyway, thanks again and i'll upload some more pics. once i get some more of these things installed
Attached Thumbnails Interior Xenon Lighting Kit-dcp_1663.jpg   Interior Xenon Lighting Kit-dcp_1703.jpg   Interior Xenon Lighting Kit-dcp_1675.jpg   Interior Xenon Lighting Kit-dcp_1676.jpg
Old Feb 6, 2005 | 10:33 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
why on earth would you want interior xenon lighting? just curious!
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
