Question about Retrofitting
Old Feb 4, 2005 | 01:12 PM
PeteyV's Avatar
W203 C230, W210 E350, W166 ML63
Im just wondering since alot of people on this forum get their bix, command, etc retrofitted after they buy the car, does it turn out cheaper doing it this way or is it more expensive? I've been impatiently waiting until the warmer months so i can really start debating whether or not to start retrofitting on my car.
Old Feb 4, 2005 | 01:27 PM
Blake P's Avatar
'09 A4 S Line
It's definitely cheaper to get the lighting package option with the car originally ($700 and change compared to $1200ish), but it's cheaper to retrofit the Comand ($2,100 compared to $1,500). As always, there are aftermarket deals to be found (especially used parts in perfect working order), so retrofitting can end up being much cheaper. I just wish I would have ordered my car with a few different options to begin with, mainly bi-x.
Old Feb 4, 2005 | 01:29 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
COMAND is cheaper to retrofit. BIX is not. the BIX C4 package cost me $750 for lights, washers and autoleveling from the factory. COMAND would have been $2100 from the factory and cost me $1500 to retrofit.
Old Feb 4, 2005 | 10:18 PM
inFiniTE LooP's Avatar
2005 Volvo S40 T5 AWD, 2004.5 C230 Sport Sedan, 2005 E320 CDI, 2008 C300 4-Matic Luxury
a lot of retrofitted BIX don't usually install the auto-leveling and washers either ...at least none that i've seen, has anyone seen or done retrofitted BIX with these?
Old Feb 5, 2005 | 01:27 AM
washers and autoleveling are not worht the cost to retrofit IMO. best bet is factory if you can.
Old Feb 5, 2005 | 01:41 AM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
Never seen it done, wouldn't do it !
I added the washer covers when I upgraded to front AMG bumper, but like
CitronC230K_03 said, the cost to fully retrofit auto-levelers and washer system is cost prohibitive. The Bi-X retrofit alone was already almost twice the original factory cost, had they been fitted; and you still loose out on not having the washers & auto-levelers.
Carlos
Saprissa@aol.com
Old Feb 5, 2005 | 04:04 PM
rnisle's Avatar
2005 C230 Coupe
Originally Posted by CitronC230K_03
COMAND is cheaper to retrofit. *** COMAND would have been $2100 from the factory and cost me $1500 to retrofit.
Is this true even in the '05's? I thought the new COMAND was more expensive to retrofit.
Old Feb 5, 2005 | 06:45 PM
SCFALIA's Avatar
2005 C230 Sport Sedan
I spoke to a guy that sells new OEM comand systems and he has 2005 sets for $1,500. It's plug and play but you need to do some modifications with the onboard computer. The modification is done so that you can see the directions on your speedometer. Steve from mbenznl can also do the install for you, from my understanding, he said that he can retrofit 2005 comand systems. I didn't get the comand system myself for my car but I'm thinking of doing it since it is pretty reliable to have.
Old Feb 5, 2005 | 08:54 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
yup, the washer thing is useless and the autoleveling is pain in the a$$ when they don't work right. last time my xenon was pointing to the ground and I could only see things 10 feet away from me.
Old Feb 6, 2005 | 12:35 AM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
I have seen it done...I even did it...on my own R129 SL...xenons plus headlight washers plus autolevelling...and on my W202 C-class...xenons plus headlight washers plus vacuum levelling...
greetingz,
Old Feb 6, 2005 | 05:22 PM
Saprissa's Avatar
that's cus you're DA Man !!!
is there anything Steve can't do ???
Old Feb 7, 2005 | 01:15 AM
PeteyV's Avatar
As far as I know Steve is def. the man. Hopefully I can make it to his spring Chicago trip so i can get bix and comand installed.
Old Feb 7, 2005 | 01:17 AM
PeteyV's Avatar
One more question, when the COMAND is installed, do you get the navigation features, or must you go to the dealer and subscribe for whatever navigation things it needs?
Old Feb 7, 2005 | 01:53 AM
you dont need to subscribe for navigation, all you need is the discs which you can either get from your dealer or off of ebay if you can find them
