W024 Owners - Post your car problems
Old 12-06-2008, 04:40 PM
  #126
mschulz55's Avatar
C300 380SL
Cool W204
Only problem the speed limit is to low car like's the upper side of speedometer though no tickets yet
Old 12-06-2008, 05:01 PM
  #127
akbro93704's Avatar
2014 C250 sport
Since I got the car in June of this year:
1. Came from the factory with an off center steering wheel. FIXED.
2. Came from the factory with bluetooth microphone that didnt work. FIXED.
3. Slightly rough engine when accelerating (thread on this) (not checked yet)
4. Cracking sound from rear shelf (not checked yet)
5. Rattly metallic sound from instrument cluster when first accelerating at low RPM's, off and on. (not checked yet)
6. Popping sound from steering when backing up (not checked yet)
Old 12-06-2008, 05:14 PM
  #128
RLE
RLE's Avatar
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Not that often
Originally Posted by wase4711
supposedly, every 4 times you do the windshield, when the lights are on..
Every tenth time if lights are on.
Old 12-07-2008, 11:28 AM
  #129
Moto_Guzzi's Avatar
2008 C350-Sport-AMG-Active Agility Pack + B170 2008+Mitsibishi+Mazda
Folding Mirror maybe
Everything perfect, except I heard a running on noise of one mirror I think after parking away a couple of times..Think I wait till it brakes, easier for dealer to diagnose. I actually mentioned to the salemen on purcharge I don't think these mirror motors are going to smoke it, only cheap sounding component noticed.
Old 12-07-2008, 05:43 PM
  #130
Egonvdv's Avatar
E 300 AMG-Line diesel-Hybrid - 2021
After 1 day of owing it, a warning light
came on advising a problem with the seatbelts "Emergency tensioning device"
saem was fixed.
Now need to make a new appointment for
- auto gearbox not shifting smoothly when driving at speeds below 60kms.
- wipers/rainsensors working very erratically + no difference between
position 1 (operation with low sensitivity) & 2 (high)
- left wiper (ball bearing?) making a squeeking noise
- wind noise left rear window
- loose dashboard panel which vibrates
(the bottom part of the hood which hangs above the display.)
Old 12-08-2008, 02:12 PM
  #131
orie's Avatar
2008 C350 Sport
Originally Posted by rb23lb
maybe this is a malfunction, maybe this is my bad...
i thought the car would clear all the parking blocks so i havent been as careful and I parked the car in a lot and the front amg bumper on my 350 sport scraped on the parking block...
when i pulled back it popped the bumper out of one of the clips and left some deep scratches in the plastic on the underside... it is only visible if you lay on the ground and loook under, and I was able to pop the bumper back in the one clip it popped out of, so everything is fine, but it just pisses me off that mercedes would make it so low in a stock configuration as to where it wont even get over the parking blocks of standard size... if this is the case they should at least warn you
I've ripped the bumper off my 2000 Jetta multiple times because of this. It's highly frustrating and annoying to say the least.
Old 12-08-2008, 05:30 PM
  #132
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
Had my first "Oh $h!t" momment yesterday at the gym. I didn't hear anything pulling in but heard/felt the scraping when backing out. The paint is scraped but like others have noted, it is only noticeable from below. Guess I will have to change my habit of pulling as far forward as possible...I have always done this to avoid someone swinging into while backing out. Good thing the C is pretty short.
Old 12-09-2008, 07:45 AM
  #133
killacam7479's Avatar
2009 C300 Sport 4Matic, 1999 Jeep Grand Cherokee Laredo
This could just be the result of my lack of knowledge on cars, but I think I may have an issue. I recently switched to "C" from "S" (after figuring out how to, haha) since I'm at 600 miles and I wanted to take it easy until 1,000.
My drive to work is only 10 miles, so I always have my center view on the one with the trip data, and one is the miles per gallon. I try to get it as high as I can, so I will accelerate to about 50 or 60 then let go and coast to get it higher.
However, I've noticed that when I do that, it slows down really fast (almost like I'm breaking, even though I'm not). Is that normal? Is that something with the car downshifting? It doesn't seem to coast very well, I can feel it slowing much harder than expected. Any thoughts?
Old 12-26-2008, 07:38 AM
  #134
tategoi's Avatar
W204
Old 12-26-2008, 12:20 PM
  #135
Diesel Benz's Avatar
Your expectations are wrong! Honestly the car is supposed to apply engine braking like a manual car would do when you lift the gas pedal.
If you wanted to keep steady speed, keep the pedal pressed accordingly (or cruise). Only old fashioned auto trannies do not allow engine braking. Note that this also does allow you to save fuel on a downhill road, fuel injection is cut while another tranny would put the engine idling.
To save fuel, you are supposed to accelerate well (not full gas but a good deal) and then keep the speed steady if the traffic allows. This gives the best average engine efficiency.
Old 12-26-2008, 05:16 PM
  #136
C300Sport's Avatar
Does anyone know how much engine "braking" is required before the fuel flow is shut off? It is my understanding that gentle engine braking is not enough cut the idle flow. I assume this is to ensure there is no stumbling when the car is in the gray area between idle and engine braking.
Old 02-15-2009, 10:46 PM
  #137
ISPEEDM3's Avatar
E46 M3 & C300 MB
its been a year and 3mo now:
1. headlights would go out for no reason and then flicker back on
2. Mirrors would squeak and opening and closing (was told that that was normal by dealer) took back various times to get "oiled"
3. eversince i took delivery, motor shakes in the morning with a ticking sound (was told that was normal by dealer) have left a numerous of days and they found no problem..weird
4. navscreen would shut off and go blank from time to time.. dealer fixed
5. tire pressure monitor system would always go off with false reading. dealer fixed
my wife and i have had a very tought time with this car.. at one point we even try selling it, but due to MB fearce devaluation, we would have ended up losing money..
we dont think we will ever buy a MB again..
although we are keeping this one and hoping for the best in the future
Old 02-16-2009, 01:51 PM
  #138
cdye12's Avatar
09 C350
ISPEEDM3, did the dealer say what had to be done to fix the Nav screen issue you experienced? This happened to me once a couple of weeks ago while I was driving on the freeway. The screen started to flicker and would go out for roughly a second at a time. I opened and closed the Nav unit 3-4 times and it stopped doing it. I'm going to mention this to them when it's time for service A and it would be great if I knew what they did to yours.
Old 02-16-2009, 07:25 PM
  #139
flexdmc's Avatar
13 ML350
Around 8K miles on her now
When I first got the car at around 1K miles, the sunroof was having issues not closing properly and stalling. Dealer replaced module and said it was fixed. 2 days later it came back.
They reprogrammed per a bulletin and it's working properly now.
Small noise coming from drivers side pillar. Probably from the tint I got. - Took cover off and saw some tape that was shoved off. Moved and no issues
I have the low AUX input volume issue. Are the dealers fixing this issue for free or will I have to pay for the amplifier module?
Other than that, the car has been fine. Still miss my BMW handling and road feel from the steering wheel
Old 02-16-2009, 09:40 PM
  #140
ISPEEDM3's Avatar
E46 M3 & C300 MB
they said they reprogramed the unit with new software..per dealership.
Old 02-16-2009, 10:14 PM
  #141
cdye12's Avatar
09 C350
Thanks. I recently got my 09 C350 back after taking it in for a consistent squeak coming from the shelf behind the rear roller shade as well as a resonating/vibrating sound coming from the driver side seat belt housing. They took each area apart and installed felt then re-tightened everything, so far so good.
Old 02-23-2009, 07:56 PM
  #142
mkaresh's Avatar
My sister did the same with a 2002 Jetta. She blamed the car. German engineers of course believe it's up to the driver to adapt to the car.
On the C204, I see many owners reporting minor repairs in this thread, but TrueDelta's survey results so far indicate an average repair rate. So the number of posts in this thread probably justs indicates that this is an active forum, and there are also many owners who have had no problems.
Mercedes-Benz C-Class reliability comparisons
Old 02-24-2009, 01:02 AM
  #143
G-10's Avatar
C350
My problem is my wife gets to drive it all the time!!!
Old 02-24-2009, 01:32 AM
  #144
JohnGjolaj1's Avatar
88 560sl, 08 c350
Owned my c350 for about a year and 1 month. 30k miles on it. NO PROBLEMS AT ALL TO REPORT. Thank you mercedes. stay classy
Old 02-24-2009, 01:45 AM
  #145
cvkatigbak's Avatar
C300 MT, 350Z
love the manual tran. no problems since day 1
Old 02-24-2009, 09:27 AM
  #146
jrct9454's Avatar
'14 GLK250 Diesel
Yeah, well, not many people come to post on a "problems board" who haven't had problems....
We're currently at 13k miles, and 18 months, with nothing to report. NOTHING. I've owned 53 cars since 1962, [including 15 Mercedes], and this is a first.
Old 02-25-2009, 04:00 AM
  #147
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Wow John, I have only owned 12 vehicles in 24 years & one Mercedes.We were a two car family from #7.
1.1950 BSA Bantam 125cc motor cycle. Had to change down in a headwind.
2. 1951 Wolseley 680 twin ohc , Twin 1 1/4 SU carbies , flat our at 86mph with no muffler.
3. 1965 General Motors Holden Utility ( Pick up)6 cyl
3. 1968 General Motors Holden Utility 6 cyl
4. 1958 General Motors Holden Utility 6 cyl
5. 1970 Ford Utility.6 cyl.
6. 1973 British Leyland P76 with Buick designed 4.4 ltr V8.
7. 1968 Ford Utility.
8. 1979 Peugeot 504 4 cyl cross flow head ,dual throat carb,all indep suspension,4 disc brake ,450,000 km without head removal.
9. 1973 Chrysler utility slant 6 low compression.
10. 1992 205 Peugeot hatchback.
11. 1994 Peugeot 405 sedal 4 cyl.diesel ,270,000 km & still in the family
12. 2008 W204 C Class 220CDI.12000 km.
Old 02-25-2009, 07:44 AM
  #148
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
Blower stoped working on the coldest day this winter. I had to wait a week and a half for a new one to come from Germany. Strange thing though is it started working after it warmed up in the AD's shop. Also my check washer fluid light will not go off and the sensor has been replaced once already. worked good for a week.
Old 02-25-2009, 10:01 AM
  #149
TB5...'s Avatar
2009 C300 4Matic
when i get into my car... the steering wheel is not in the location is should be... i have to press preset [1] to get it to move...
the passenger window doesn't got up automatically... i have to hold the window up button... and also when it does go up... it sometimes automatically comes back down an inch or so.
Old 02-25-2009, 10:13 AM
  #150
cdye12's Avatar
09 C350
Above stated problem happened to me. Screen started to flicker white 3 weeks ago and was an intermittent problem. This past weekend the screen turned almost all white; took it into the dealer and they are having a new screen shipped in after Mercedes-Corporate "authorized" its replacement. Service summary stated they did a software flash and checked all of the electrical wiring before narrowing it down to a faulty screen.
Quick Reply: W024 Owners - Post your car problems
