What temperature does your W204 run at? What is normal running temperature?
2008 c300 luxury, P2, MM, Capri Blue Metallic
well, you've obvioiusly already done it man, so your "reasoning" is just a moot issue at this point..
Everyone breaks in their car their own way, so do what you think is right.
RPMs are under 3200 when around 100 MPH, this is less than the 2/3 of max rpms, right? isnt that what the manual says to watch during break in?
2/3 * 8000 max rpms on the tachometer = 5,333.33 RPMS is the max I should ever get close to while in the break in period...
Is that the correct reasoning as to what 2/3 actually means? or did I read that wrong... not going over 5,333 rpms during breakin isnt that hard....
all you have to do is avoid flooring it, thats about it...
please correct me if I am wrong?
During break in you are supposed to avoid putting a lot of strain on the car, which is why the maximum speed should be below 85mph. If you accelerate slightly beyond that for short amounts of time, as long as you do not accelerate quickly, your engine should be fine.
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
2/3 of maximum RPM is about 4000, not 5333, since the maximum engine rpm is about 6000, not 8000.
so the engine tachometer goes up to 8000 at the end of the red, but 6000 is max?
If that is the case, I caught myself once at about 4800-5000 during a freeway onramp merge...
do you think doing this once or twice before 1000 will cause a noticeable performance or gas milage effect in the long run??
other than that I have babied it so far...
2008 C350
2008 - S550 4Matic, 2010 - E350 4Matic, 2010 - C350 4Matic
With the speed limits we have in North America there is nothing to worry about. The car is designed for much higher speeds.
Jorg
Jorg
#32
[QUOTE=rb23lb;2490168]so the engine tachometer goes up to 8000 at the end of the red, but 6000 is max?
QUOTE]
The maximum engine speed is where the red starts (by memory 6000-6200 rpm, I forget what it is for the 350). Usually any instrument will read higher than it needs to, the capability of the car is not just the capability of the instruments. Remember, these instruments are also used in manual shift cars, so someone could mis-shift into the red, which is why it needs to read beyond the max engine speed.
QUOTE]
#33
1 Post
'14 GLK250 Diesel
Update...
After participating in this discussion, I decided to really pay attention to the gauge on our next drive, just for yucks.
This morning, with ambient temp around 45-47F, we left with a cold engine and were on the freeway after about 3-4 minutes of surface streets. At a constant 65 mph, it took a total of about 4 miles to reach full operating temp, which was 85C on the gauge. The total trip was about 16 miles, and it stayed steady at 85C once warmed up, all the way back to our garage and final shutdown.
On our long trip, where we saw 90-115F outside for nearly two weeks, and the AC blasting the whole time, we never saw the coolant temp go over 90C, no matter what was happening outside. So whomever said that "normal" was 85-90C, that sure fits our experience....for whatever it's worth....
#34
C180K 2011 COMAND, AMG, Dynamic Xenon, Business Pack, H&K Audio and +
83C on the gauge all the time. outside temprature was 13. but i was driving slow in the city and some minor trips over the highway with top speed of 100km
#35
c300
I actually watched mine today too. Most of the time it sits where everybody else describes. But then I noticed that when I started driving the car hard, temp needle went to middle of the gauge and stayed there until I started driving normally ... then it went back up.
Just food for thought.
#37
1997 E320
Thank goodness I found this thread as I was too wondering about that. My gauge sits at 90-92 degrees celcius, where my old 97 E320 never gets over 80 even in traffic.
#39
92 C?
The folks who mention precise temperatures to the degree like 92 and 83 degrees, is this a feature on the multimedia package that gives the exact coolant temp? I don't have the multimedia package on my c300 and all I have is the temperature gage that starts at 40C with a marking at 80 and another at 120 with 5 degree markers among them. Mine hovers between what would be 85 and 90 which is the normal running temperature for most cars I've had in the past few years. However, I think it was a stupid idea from mercedes to grade the gage linearly at 40/80/120 instead of a non linear 30/90/120 and have the gage pointing in the upper half of the scale. It just doesn't look right.
#41
Former Vendor
Any AMG Thats Around..
in all the benzes that i have been in and worked on, including mine... its always alittle higher past center.... dont know why they dont center their gauge... lol alot of us are used to american cars where most of the gauges read the center as normal.... but benz likes to be different....
#42
2007 E63
#43
1997 E320
#44
1 Post
C-300, XC70, Wrangler
- This may simply be a fluike of the thermostat in the cooling system ... but it's most likely well within the acceptable tolerance range.
- The red mark's at at 120 C, so running 90 or 92 C seems of no consequence
But mostly: being hotter, it means the heater works better in winter!
(I like being warm.)
#45
2003 SL55, 2010 C63
After start driving for about 5 minutes the temperature always stay at around 82-83 on my W203 no matter how fast or slow I drive it. Your car runs at 90-92 is a bit high but I think it's still normal though.
#49
Both my CLK and my ML always run a bit over 80c. Basically the needle is just a hair over 80. But I do notice with the C300 the needle goes a bit higher than the other cars. So I would say its at about 90c. Definitely a difference but I figure since its a new car it must have a new temp setting. But it is noticable if you are coming from another Benz.
#50
MY2001 C320
MB temp gauge is marked at 40, 80 and 120C. VW marks theirs at 50, 90 and 130C and the needle is at middle. So I think 90C is where running temps should be and the way MB marks the gauge it is always above the middle.
