What temperature does your W204 run at? What is normal running temperature?
Old Feb 18, 2008 | 04:02 AM
  #51
Untertürkheim's Avatar
Originally Posted by djf1
as I said, my 97 E320 is always hovering at or below 80c which is the middle of the gauge. On the freeway it is always below the 80c mark. That is why I really thought that there is a problem...
Your car is running too cold, it should be 82-85 C, never lower.
Old Feb 18, 2008 | 12:00 PM
  #52
AsianML's Avatar
2007 E63
Yeah, I have the same engine and it always hovers above 80C...which on my cluster is dead center the way they designed it.
Old Feb 18, 2008 | 10:08 PM
  #53
djf1's Avatar
1997 E320
Is that a bad thing???
Old Feb 18, 2008 | 11:01 PM
  #54
micropower99's Avatar
2008 Mercedes C300 4Matic
mines in the low 90's, i would guess under 80 means something's wrong, but you should ask a mb technician just to be sure so you get an official answer on the corrrect temp.
Old Feb 23, 2008 | 03:37 PM
  #55
acr2001's Avatar
2012 C300 4Matic
Yes running too cold can be a bad thing. The engine is supposed to get up to a specific operating temperature in order to burn fuel / run most efficiently. Not to mention for the heater to work optimally. Running too cool can put excess wear on your engine and cost you MPG. The guy who posted (I'm paraphrasing) that 'if you want to keep the car for a while it should be running cooler' couldn't have been more wrong.
The proper temp is just a bit above the center on the gauge just like everyone here is saying. I don't understand why there are so many questions and so many people saying otherwise.
It's a fact: The normal operating temp for these cars is ABOVE THE CENTER LINE. If your car runs a little cooler I really don't see any problem with that. If it runs a lot cooler than yes you should have the thermostat and temperature sensors checked out.
Old Aug 30, 2014 | 04:39 AM
  #56
kilan97's Avatar
w204
The ver mb owners manual for W204 did mention the normal operating should be below 70 !!!
Old Aug 30, 2014 | 07:15 AM
  #57
AusMB87's Avatar
W204 MY10 C200CGI
Qualified MB tech weighing in:
90c is normal operating temperature for for these vehicles.
If you are running cooler it's either a jammed open thermostat, dodgy sensor or a faulty control unit (very unlikely).
If you are running hot, by which I mean consistently closer to 100, you should take it in to get checked out
Old Dec 29, 2015 | 05:11 PM
  #58
mtripcev's Avatar
C220 CDI W204
on my c220 in winter temperature never go above 60c. but in summer temperature is normal (under 90c) but on highway is going down to 70c. does I have problem with temperature sensor ? or is something else ?
Old Dec 29, 2015 | 08:06 PM
  #59
michail71's Avatar
2013 C250 Sport
Actual coolant temps vary considerably compared to the gauge. I've seen logging data vary over 10 degrees during operation while the gauge stays put. The data will show typically from the lower 80s to the lower 90s. There must be some sort of algorithm they use.
Old Dec 30, 2015 | 05:14 PM
  #60
MaineSailor's Avatar
2008 C300 Sport 6spd man.
Originally Posted by rb23lb
anybody else have a temp gauge reading at 90-92 C ?
Plus one for us. 2008 C300 Sport. Has run about 90C always. The temp gauge calibration on this car is a bit wierd - doesn't seem really linear. Makes you stop and study it to figure out the temp. If I were designing the car, "normal" operating temp would be exactly mid-range (horizontal).
Old Dec 31, 2015 | 08:43 AM
  #61
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
Yeah I think there is an "averaging" algorithm in use. If you take the actual OBD rating it usually bounces between 80 and I believe 95C which is the temperature at which the thermostat opens up. I've seen it very briefly spike to 100C a few times but the dash is always reading just about the same value.
Old Jan 1, 2016 | 12:14 PM
  #62
edgalang's Avatar
Factory ordered 2012 MB C350 w/Dynamic Handling Package
A thread back in 2014 asking the same thing...
https://mbworld.org/forums/c-class-w...ure-gauge.html
...answered with the same questions on this thread.
Old Jan 2, 2016 | 01:22 PM
  #63
mtripcev's Avatar
C220 CDI W204
my question was about very low temperature. in winter ( for example outside temperature around 0 degrees) temperature gauge is not passing 70 degrees, and if drive on openroad is going down to 60
