headlights ????HID
Old Nov 30, 2007 | 04:18 AM
ace8's Avatar
c350
headlights ????HID
Im planning to get some HIDs I was wondering what bulbs is it h4 or h7? please help
Old Nov 30, 2007 | 10:36 AM
Blue_Monster's Avatar
215
Both headlights and foglights are H7 bulbs. I know because I replaced both with HID 6000K
Old Nov 30, 2007 | 04:08 PM
MiKeSSw203's Avatar
From: South Coast Metro/Cerritos/Yorba Linda California
'05 C230K '10 GLK350 '13 SMART
Old Nov 30, 2007 | 05:48 PM
alphad's Avatar
e92 335i
are the stock lights 45OOK?
Old Nov 30, 2007 | 09:24 PM
peabers's Avatar
2011 E350 4Matic Wagon, 2013 C350 4Matic Sedan
Err, 4300K?
STFF... https://mbworld.org/forums/c-class-w204/219893-6000k-8000k-hids.html
Old Nov 30, 2007 | 09:55 PM
Raydens's Avatar
c300SpP1
blue monster, how do you change the fog light to HID? I'm trying to do the same and have to deal with drilling the OEM H7 socket and then running into flickering issues. Fog lights are OK when ignition is on ACC but when ignition is ON, the HID fog lights are flickering and eventually shut off.
I am waiting for another emulator to bypass/trick the computer.
How did you do yours?
Old Nov 30, 2007 | 10:05 PM
JCsE350's Avatar
08' E350 with P2 & AMG sports package, 03' BMW 325i
You can purchase a HID anti-flicker anti-error PnP device from jlevistreetwerks.com. I just happened wandering around on their website.
http://jlevistreetwerks.com/p990/üm·...duct_info.html
Old Dec 1, 2007 | 01:27 AM
ace8's Avatar
c350
DO I NEED BI XENON? Or can i use the regular hids?
Old Dec 1, 2007 | 09:14 AM
JCsE350's Avatar
If you want Bi-xenon, either change the whole headlight assembly or change the projector lights (this is lot of work or probably undoable task) and then you need to bring it to the dealer to reflash your ECU. All you need is regular HID set-up (comes with a pair of HID bulbs, a pair of transformers and a pair of of igniters) and you'll need the anti-flicker device that I posted earlier
Old Dec 1, 2007 | 03:29 PM
MBE50003's Avatar
Dad - CL550, Me C350, Sista B8 A4
my DDM tuning kit came with some wires that specifically fix that issue. had that happen on mine as well, exactly as you were saying it. fixed it in 2 mins
Old Dec 1, 2007 | 09:32 PM
Andr3an's Avatar
w204-C300
What is the difference between Bi-Xenon and HID?
Old Dec 2, 2007 | 04:00 AM
GPI's Avatar
GPI
W203 (sold), W204 (sold), W124
Bi-xenon has auto-leveling function of the projectors while projectors with HID do not. If you observe the HID headlamps of the new G35, they do not self-level.
Old Dec 2, 2007 | 04:34 AM
Cal's Avatar
Cal
2018 Porsche Macan, 2017 NSX, 2011 R350
Same here. If you get a DDM kit, you get the anti-flicker stuff included. No need to buy a separate one. Check the GB section from StealthAuto. $175 for the kit with lifetime warranty.
Old Dec 3, 2007 | 01:08 PM
Lakerz4sho's Avatar
c300 sport
Dudes, i bought a DDM 4500k kit for my lowbeams, and I am getting the bulb out error as soon as I turn on the engine.
with engine off, I can turn on the lights fine and no flickering. But as soon as I turn the engine on, the lights turn off within 30 seconds, and then soon after that, I get the "bulb out" error for both left/right side.
I don't think mine came with separate wires? Are you guys talking about the add-on relay harness or whatever?
Will getting the Xenon=Present command changed fix this issue?
Old Dec 4, 2007 | 12:53 AM
Moviela's Avatar
Post Primer on lighting
They are the same. HID=High intensity discharge lamp.
Xenon=the gas in an HID lamp
BiXenon=an HID lamp system with a mechanical vane to cutoff part of the beam.
Projector=lamp holder design on modern cars, a decade ago reflectors were used with HID lamps. They are inferior to projectors.
Most HID (high intensit discharge) lamps for automotive use are 35 watts. They are made in two basic color temperatures, 4300 and 6000K. There are minor variations around these basic temperatures, depending on who makes them, and what gas is inside. Higher color temperature lamps are not brighter, but they are more blue. 6000K lamps from Philips (best in my opinion) measure about 25% less light. The 10000 and 12000K lamps are usually lesser quality lamps with optical coatings that increase color temperature, but greatly reduce the light.
Early on European manufacturers used xenon lamps with reflectors. They are out of favor now because projector stlyes are so much better. Those early reflectors had a bluish appearence because of the reflector coating, not the lamp. The lamp is a 4300K unit.
Mercedes Benz Bi-Xenon (high and low beam being the Bi part) lamp assemblies are made by Automotive Lighting by about a thousand people in the Czech Republic. Bulbs are from Germany, and electronics are from France. Cars with factory Bi-Xenon come with sensors on the front and rear axel that adjust the beam automatically. Many people who fit the lamps after market feel that this is not necessary.
Philips has made some lamps in automotive style bases that are 50 watts. They are labeled "Not for automotive use in Europe and USA." If you can find them, they are the ones to have, if brightness is your goal.
Some people feel they see better with Philips 6000K lamps, and their opinoins are to be respected, however, they do report also that visibility in rain and fog is diminished. Those lamps do look more blue, like the earlier reflectors, and some people like them because it makes their car different from the crowd, which I think is cool.
Cheap lamps from China are often sold with inflated color temperature claims (how would you measure it, anyhow?) and 300 hour lifetimes. Philips and Osram (Sylvania in the USA) lamps are very near the specified color temperature, and their lifetime is about 2000 hours. Color temperature variations from lamp to lamp are visible to the eye, so the lamps are offered for sale in matched pairs. Automotive Lighting matches the lamp assemblies it makes for Mercedes production lines. Another wrinkle is that there are couterfeit lamps from China marked Philips. Many of these are sold in kits on the internet.
If you do put Bi-Xenon lamps you need to change a setting in the cars computer at a dealer to Xenon=Present. The computer is checking the lamp current, and the lower wattage of the xenon lamp can cause them to flicker if the computer is not set correctly.
There are after market housings, most notably from Depo, for about 500. The dealer will charge about 2400. for a set. (ouch, they are only 800. as an option.) There are also "HID" look units that use regular haogen lamps, but are not worth having. For me the after market sets like Depo would be great on a lease car I am turning in, that had a broken housing or lens.
Lots of kits out there that put new bases on cheap HID lamps to fit in halogen housings. Biggest problem is the reflector is not designed for the HID light source. You get the color, but risk damage to the housing, and will probably have less visibility than stock halogen. If you just want the look, Silver Star halogen lamps for less than 50. are a good choice.
There are some questions you need to ask any one that sells kits to convert to HID lamps:
Is the conversion beam pattern correct?
How is the conversion made to be beam pattern correct?
How is the conversion tested to ensure beam pattern correctness?
If it is not beam pattern correct, can they tell you how to fix it?
Do they know what a correct beam pattern looks like?
Are they aware that non-beam pattern correct conversions have serious disadvantages? A person could get hurt!
