What NOISES do you hear from the INTERIOR when driving with the radio off?
Old 09-22-2009, 12:15 AM
  #51
Distalero's Avatar
C 300
The heat related cracking sounds when the car sits in the hot sun, I have that, but I more or less expected it. No way to get around the dynamics of heated material, and the noises go away after a couple of miles.
I've heared the passenger side lower speaker rattle a bit over a road that has a lot of little bumps in it, although it hasn't done that again. As of 2 days ago I noticed that the driver's side high speaker grill rattles a bit, but it's disappeared in the last day. I go for my A service this weekend so I'll mention it.
Whatever is put together, slowly comes up-put over time.
Old 09-22-2009, 05:46 AM
  #52
albert101's Avatar
W204 C280
Originally Posted by RLE
Nothing. Nada. Quiet as a graveyard at midnight. Well, except for the tire noise on the pavement.
It's either you drive on the smoothest roads in the world or you found yourself a gold mine of an interior in your car!
Old 09-22-2009, 05:48 AM
  #53
albert101's Avatar
W204 C280
Originally Posted by akbro93704
I have:
1. A-pillar popping (if I press on the A pillar trim, I can reproduce the sound). I notice this mainly if I accelerate from a stop with moderate to a lot of throttle.
For the A pillar popping sound, my dealer stuffed my A pillar with foam. It worked and the sound went away and its been quiet ever since.
Old 09-22-2009, 06:19 AM
  #54
Peabody's Avatar
I hear wind mostly, and on certain roads I will have some tire noise. Luckily, the car itself doesn't make any rattling, cracking, or popping noises.
Old 09-22-2009, 07:19 AM
  #55
acmf74's Avatar
C300 4matic & ///M3
my wife telling me to slow down
Old 09-22-2009, 03:51 PM
  #56
RLE
RLE's Avatar
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Noises?
Close to it. Beige leather with no creaks, cracks or squeaks. Early car, too.
Attached Thumbnails What NOISES do you hear from the INTERIOR when driving with the radio off?-beige-leather2.jpg
Old 09-23-2009, 08:33 PM
  #57
akbro93704's Avatar
2014 C250 sport
Man RLE, you're lucky! Since yours is an early build, it's German built.
For everyone with the creaking/cracking/rattling complaints, are your cars German built or South African? My car is South African and I have most of the cracking noises as described in this thread(..and I say previously stated).
It'd be interesting to see if there's a correlation in creaking and where the car was built. One of my good friends has a South African built C350 with multimedia, and it has all the same sounds from the dashboard that mine does. Maybe even slightly more because of the Nav screen.
Just curious!
Old 09-23-2009, 08:55 PM
  #58
albert101's Avatar
W204 C280
My car is a Germany built car. I also have the sounds coming from the Nav screen. I usually just keep it in the closed position when I drive since it would make less noise in the closed position. But it still makes noise!
Old 09-26-2009, 01:26 AM
  #59
S204HONGKONG's Avatar
W212 E250 AV
I still have that creaking noise from both B-pillars. I have visited the local (monopoly) Hong Kong dealer for fixing the noise 4 times. They say it's a minor issue so I don't get a loaner car when I bring it in. The last time it took them 3 days, the noise did went away for another 2 days and the creaking sound came right back! F-king frustrating! Their attitude is OK, they are willing to help me, but every time the noise only disappears for 2 or 3 days at most after the SC visit.
OK, so my car is a wagon with the AMG pack sport suspension and 18inch wheels, which makes it one of the hardest-riding C-classes this side of a C63, but should these kind of creaking sounds develop after just 1 year?
Old 09-27-2009, 12:30 PM
  #60
Peabody's Avatar
Mine was built in Germany. Also, here's a video so you can hear what I hear.
Old 09-27-2009, 02:30 PM
  #61
JoeVal's Avatar
C350 Elegance
Smile
I am happy to report that the only sound in the cabin of my C350 Elegance built in Germany (Sindelfingen) is the sound of silence. Then again, though roads are not too good in Argentina, where I have it, I almost never run over 200 Km/h (125 mph).
I am also convinced that MB is building two qualities of cars (standard and extra cost under different names) changing traditional policy.
Cheers, JV
Old 09-27-2009, 04:23 PM
  #62
dalazernet's Avatar
2020 GLC300 4MATIC
Quiet one here... no noises... lux '08 from germany :-)...
That being said, I rarely drive anywhere without the radio on - but I did for a while just to check for everyone...
- Eric
Old 10-02-2009, 04:38 PM
  #63
flagman's Avatar
2016 C450 AMG, 2012 C350 4Matic Sport
So far so good with mine also, except for the tire noise. The tire noise in this car is pretty loud - almost a rumbling from the rear. I have the stock Pirelli P Zero Nero's (staggered setup so I can't even rotate them in case it's a bad tire). Anyone else find this to be the case on their car?
I think this car needs more insulation in the rear wheel wells - pop out your first aid kit cover or the one on the opposite side of your trunk and look at all the empty space in there.
My previous car (05 Acura TL) had styrofoam insulation filling these void spaces, and even a sort of felt finish on the plastic wheel well liners to cut down on road noise - that car was very quiet. The lack of attention to detail by MB is a bit disappointing.
Old 10-04-2009, 09:55 PM
  #64
albert101's Avatar
W204 C280
I know on the newer models of the C class, Mercedes made some changes to the interior in attempts to sound proof it better and make it creak less. I know friends with newer 2009 models and they don't have the same creaking as I do. We opened up some of their interiors and noticed there was felt placed in strategic places. I suppose that helps with making the creaking go away.
Quick Reply: What NOISES do you hear from the INTERIOR when driving with the radio off?
