Questions about fog lights
Is there a setting where you can leave them on all the time with your headlights? I feel silly just driving with only one of those lights lit.
Also, you know the headlight settings.. where it says A, P, etc... are those lights on that panel supposed to be lit up as well during the night time? That control is dark for me except for the green symbol lit up underneath the circular knob.
As for your question, on North American cars there is a single rear drivers side fog lamp. It's there so cars following you in foggy conditions will see you better and not rear end you. As for the other questions, I will assume you have the p2 package, because the fog lights on the p2 package illuminate at slow speeds when turning corners depending on which direction your turning the left or right fog light will light the corner. And for the other one, you can't have the fog lights on while the switch is set to auto, you must turn it to the headlights on position, then pull out one click for front, two for front and rear.
This makes sense now. I was trying to pull the knob out while in the A position and wondering why it was not going. I will look for the rear fog light on the back of the car now to see what it looks like
