Navi and Vcards
Old Jan 2, 2008 | 10:02 AM
red309's Avatar
C300 4 Matic
Navi and Vcards
Does the Navigation system recognize the addresses in a Vcard? Has anyone tried this?
Old Nov 7, 2010 | 12:55 AM
chicagoguy's Avatar
2024 C300 Sport Sedan, 4Matic, Nav, PanoRoof, Black/Red
On my 2011, from the Nav screen selecting the Destination menu doesn’t give an option to select an address from the Address Book. (Pics 1 & 2). However, if you access your Address Book through the Phone menu and pull up an address, there is an option to navigate to the address (Pics 3 & 4).
All of my addresses were imported Vcards (iPhone 4, Outlook, PCMCIA/SD situation) including the one shown. But the Navigate option is always grayed out for me. The COMAND Operator’s Manual says “Navigate can only be selected when the address data field contains complete navigable data.” Makes sense—it needs a complete addresses to plot a route. But all my addresses seem complete to me, yet COMAND doesn’t recognize them as navigable. Pic 5 shows the details of the address in my Vcard, which seems complete to me.
In hindsight, I picked a bad example to take pictures of since some of you may think that the “W. North…” part of the address may be confusing COMAND, but that’s not the case. I have the same problem with the Navigate option being grayed out on my other apparently complete addresses. (btw, W. North Avenue is a main street near me, and I have no problem entering the address in the example via the voice Enter Destination method.).
If anyone has figured out the trick to entering an “navigable address”, please share.
Attached Thumbnails Navi and Vcards-001.jpg   Navi and Vcards-002.jpg   Navi and Vcards-003.jpg   Navi and Vcards-004.jpg   Navi and Vcards-005.jpg
Old Nov 7, 2010 | 02:32 AM
Diesel Benz's Avatar
On my W221 if the address in the visitor card was not recognised by Comand for navigation, I can still access it and complete the fields Comand does not recognise.
It is a bit of a problem though for some addresses where I prefer the true postage address on the phone address book while the "street address" is not the same. If I don't have the work address for this entry, I can put the home address in both formats.
Old Nov 7, 2010 | 07:36 AM
dgghostkilla's Avatar
2012 E350 4-matic SPORT
from what i've read it does recognize vcards.
i have an iphone 4 so i was never able to transfer my address book, it wasnt compatible.
i've read you can buy a PCMCIA card and export over your address book vcards that way.
I never did it that way.
I ended up buying the media interface plus which by the way is a pain to use.
with the media interface plus i was able to transfer over my address book but it only transfers numbers and first name and last name got transfer over to the last name field only. it wasn't a big deal to me. I ended up returning the media interface plus because i wasnt happy with the bluetooth performance, it would constantly disconnect for me.
but if you don't have an iphone 4 that part might now apply to you.
you can always buy the pcmcia card and export your contacts from either a pc or a mac im sure it might work.
http://cgi.ebay.com/MMC-SD-MS-PCMCIA...#ht_4083wt_907
Old Nov 7, 2010 | 07:09 PM
chicagoguy's Avatar
My last picture is a detail of the address that COMAND does not recognize as navigable. It all looks complete to me. How do you tell which fields are not correct or incomplete? I guess I'm missing something.
Old Nov 8, 2010 | 01:53 AM
Unfortunately I don't have US W204 Comand to try the address but even if your address is complete, it might not be the same the Comand unit would use for this address.
Can you try set that address for a destination by the standard address search approach and then try to save the address (I don't know if 204 allows you to save it on a specific contact).
Old Nov 8, 2010 | 08:10 PM
chicagoguy's Avatar
thanks.
Old Dec 11, 2010 | 06:02 PM
skorpione's Avatar
C300 Luxury
Hi
I have the same problem with my 2008 C300W.
We tested this at the dealorship with brand new C300. It does not navigate from imported contacts. I had tested it with perfect addresses which were recognized by GPS to Vcard converter program, which inserted the lat./long. coordinates.
When we tested the same address import into another E-class car via the PCM/CIA adapter, it was able to navigate.
So, does C300 need an upgrade of s/w?
Skorpione
Old Dec 12, 2010 | 08:24 AM
romanservices's Avatar
2011 C300 4Matic Sport
i have an '11 and could not get the Vcard address to work. I guess they don't! I will try the PCMCIA mtheod
