Quote:
The "manual" gearshift feature on the W204's autobox is only available as part of the Advanced Agility Package which gives you a third mode for the gearbox, i.e. C, S and M (for Manual) and steering wheel paddle shifters. What you guys have been discussing is the shift range restriction feature.Originally Posted by Rick Hunter
Yup... totally agree. I played around with it too. This system's quite useless, as it doesn't shift the way a manumatic should. Whatever you determine as the gear is the top gear it'll go to, but will still shift up/down like a regular automatic. It's not really a manual control.
I bet they could fix this with a software update... The hardware is already there, right? Any chances of that happeing?
Quote:
Nope tried the M as well. The clippers behind the steering wheel. There is a same lag there as well . around .8 to 1 secs to be very precise. There is no difference if you use the Stick or the clippers behind the steering wheel. The M here in Europe is not a part of advance agility. Advance agility is just a button which says sports on it which changes the handling dynamcs of the car and the car is lowerd 15mm more.Originally Posted by st13phil
Quote:
Sorry, my mistake. In the UK it's only the Sport model line that gets the gearshift paddles on the steering wheel and the Manual gearbox mode. The Advanced Agility Package (option code #483 - only available as an option on the Sport model line) gives you the sport button on the dash which provides "Sharper accelerator response; Continuously variable damping for improved ride; Quicker gearshifts via steering wheel gearshift paddles".Originally Posted by lx Raven xl
Seems that you need to spend more on options to get the quick manual gearchanges, then
Sorry, my mistake. In the UK it's only the Sport model line that gets the gearshift paddles on the steering wheel and the Manual gearbox mode. The Advanced Agility Package (option code #483 - only available as an option on the Sport model line) gives you the sport button on the dash which provides "Sharper accelerator response; Continuously variable damping for improved ride; Quicker gearshifts via steering wheel gearshift paddles".Seems that you need to spend more on options to get the quick manual gearchanges, then
Spend more on quicker gear shifts. thats bizzar!!!!
I would like to know how an automatic BMW behaves. Is it similar or not. My bro gonna take a test drive as hes intrested in BMW but dont know whens he gonna do that. so if anyone tested an automatic for manual shifts ( Audi or BMW ) please post!!
