Garage door opener
hold garage door opener controller about two inches away and press the button on the controller and on the mirror and the same time. hold them until the light startes flashing rapidly. now go to you garage door motor and there should be a 'learn' button on it. press that and go back to the car (within 30 secs) hold the same button on the mirror as when you did it with the remote. hold it for 2 long secs and let go. hold it for another two secs to confirm. you should be done. when u hold it for antoher 2 seconds, the garage door should open. i noticed you have to hold the mirror button for about 2 seconds before the garage door will open not just a quick press.
u have to hold the remote to the mirror for each button you code.
i just did this yesterday actually on an 'Overheaddoor Company' garage door.
Page 305 in the manual.
hold garage door opener controller about two inches away and press the button on the controller and on the mirror and the same time. hold them until the light startes flashing rapidly. QUOTE]
TIP: Be sure to push the homelink button first, and THEN the garage door controller. You need the homelink to be able to catch the entire signal from the controller.
It's on pg 306, but does it *require* the ignition to be on.
:My BAD!!!
