E85 - Safe to use?
C300 Sport/Palladium Silver on Black/P2
E85 - Safe to use?
I've been wanting to go find an E85 fill up station, and put some in!
However, the owners manual says not to switch back and forth too often.
You think I could do this one time, just for the fun of it?![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Has anyone else put E85 in the new C-class?
MB 2008 C300 sport, 2008 Rally blue Subaru Impreza 2.5 SI 1995 MB C280 W202
There are more E85 stations in States.
Yes....I believed that for the C300 RWD which I got one.
I heard from a friend of mine that he put one in for his GM truck but did not see any saving in term of Gas mileage. Yes the E85 have lower cost but burn the same amount or more Gas than the regular gasoline. Do this for the environment if you want or needed to. Basically in term of mileage, you won't see anything drastic.
I will let everyone know next time I going down to New York.
Administrator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
There is only 2 stations in Ottawa and one in Chatham, Ontario.
Ok, I did it. Could only get about 1/2 a tank, but that is what the manual recommends, rather than switching on an empty tank anyway.
I noticed no difference besides the decrease in MPG. It was fun to try though, if it was close to me, I'd probably get it regularly, just cause it's probably good for the world and all. ha-ha.
Also, it was my first trip in the car, about 5 hours of driving total, and it sure was a pleasure. This car is just a dream. Whatever you're doing, twisty roads, flat boring motorway, etc. It's just so enjoyable and peaceful. I love how comfortable the cabin is, with the thermostat, and how much of the outside world sound is filtered out (unless great moonroof is opened), and the great ride of course.
This really is a special car. Glad we all have one to talk about.
Coming home, even with half ethanol, I got about 25 MPG. However, going with gasoline, I got a little over 27 MPG.
hmm... i did read somewhere that because of the chemical makeup of Ethanol fuel, the fuel lines, injectors etc had to be suited to run ethanol fuel. Reason being that Ethanol was corrosive to certain materials usually used in a standard car's fuel system....
Silver 2005 Acura TSX Navi
i may be off base, but my TSX says premium recommended. for the last 33 months i have put regular or the ethonal mix(alot of stations in NJ have it) in my tank, with a few exceptions. the car runs fine, although im sure i could get better gas mileage with premium. i use regular for two reasons, A i lease the car, and i doubt this car is going to blow up within the first 3 years due to putting a slightly lower octane in my tank. and B because i rather save the money. i know everyone says oo if you can afford a nice car, you should be able to afford the gas, well i can afford it, i just dont want to pay it.
when i get my C300 4matic in a few month, i plan on also putting regular in the tank. im curious what everyone thinks.
Administrator
when i get my C300 4matic in a few month, i plan on also putting regular in the tank. im curious what everyone thinks.![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
i am not putting the TSX in the same class as the C class at all. in fact i would think that the Cclass would be even more resilient to using regular then the TSX would be. but either way, i dont think either car would break down in the first 36k miles due to this.
2007 E63
C3004Matic Sport, Blk on Blk, Pano, P1, MMC, Ipod
true
He's right, you can't put the ESpec Honda Accord (aka, Acura TSX or also the JSpec Accord) on the same level as the C Class since the TSX has actual leather, memory seats, puddle lights, etc. handles just about as well (some might say better) and more power to weight ratio, all for about $10K cheaper when comparably equipped as they say! ![slap](https://mbworld.org/forums/images/smilies/slap.gif)
But we know what you mean.
![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
2008 C350
<<<I noticed no difference besides the decrease in MPG. It was fun to try though, if it was close to me, I'd probably get it regularly, just cause it's probably good for the world and all. ha-ha.>>>
With current technology and harvesting equipment, it takes 1.1 gallons of gasoline to produce 1 gallon of ethanol so you aren't saving anything right now.
Maybe in the future though.
1.3 is the lowest worst-case number I've seen. It would be much better if farmers used switchgrass, but we'll have to see how quickly that happens, if at all. Of course, supporters use much more optimistic numbers. The truth, I'm sure, is somewhere between. At the other end, if e85 were readily available, then MB could give us a more efficient engine with higher compression. Personally, I plan to use e85 if and when it becomes available here. While the overall efficiency isn't where I'd like it to be at the moment, it will undoubtably improve as more people use it.
But - if like many, you believe the auto industry will eventually go electric, then e85 is at best a stop-gap. Of course, electricity production at the moment in the US is only around 30-35% efficient, so I guess no matter which rout you prefer, there will be inefficiencies as the industries involved adjust.
Got to start somewhere.
But we know what you mean.![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
What surprised me was TSX has 5 stars Crash Ratings and the C has 4 stars...
if you are leasing it, then by all means, put that regular crap in your car.
