License Bulb?
Old Feb 28, 2008 | 01:22 PM
theraj2's Avatar
'08C300 White w P2,MM,Pano
you went through all those steps? thats determination man! did you encounter any problems? When i changed it on my other car, you popped the lamp out front the outside of the car. I was thinking of just poping the glass off the front, did you see any pins there that holds the glass in? or is the long way, the only way?
Old Feb 28, 2008 | 01:28 PM
e1000's Avatar
a quarter mile at a time
if the W204 is anything like the W203, it will be a pain to get anything other than the stock W5W bulbs working. Most aftermarket superwhite bulbs are 10W and will melt the plastic housings. The HOEN bulbs work ok, but some people have had problems with them as well (myself included). LED's have had thier share of problems from tracking down the correct resistors needed to eliminate the bulb out warning, to them burning out very quickly (less than 1mo), to constant flickering.
Good luck guys and hope you guys have it easier than we did!
Old Feb 28, 2008 | 02:07 PM
SNOW's Avatar
'08 C350
There ARE pins that hold the housing and the glass/plastic cover from the inside, which is why you have to go thru so many procedures. I don't find the bulb lamp warning much of a nuisance, so it isn't a big problem at all. We'll just have to see how long these things last untill they burn out...
Old Mar 14, 2008 | 06:58 PM
Saks_C350_Sport's Avatar
CLS63
FINALLY installed, or tried to anyays, my Hoen plate light bulbs today. When I first turned on the parking lamp switch, both lights illuminated. After a second one blinked on and off, and I received a dash display bulb out alert. I returned my stock bulbs to the harness and reinstalled my deck-lid liner. I just order resistors online and will update you guys when I get them next week. I hope this works. I LOVE the look of the LEDs on the newer Lexus'.
Old Mar 29, 2008 | 06:46 PM
CLS63
Installed my LEDs and resistors today:
Old Mar 30, 2008 | 01:44 AM
Quinni's Avatar
2020 GLE 400 D and a 2024 EQE 350SUV
Originally Posted by theraj2
Anyone know how to get to them?
I preume you mean the Licence plate bulbs on the C (W204)
Im trying to upload 2 pages from the WIS manual for you.
Basically you need to remove the Trunk lid handle assy to get access to the bulb from behind.
Hope this helps.
Cheers
Quinni
Attached Thumbnails License Bulb?-trunk-lid-handle-remove-1.jpg   License Bulb?-trunk-lid-handle-remove-2.jpg
Old Mar 30, 2008 | 11:13 AM
  #32
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
Sounds and looks easy but it is a lot of work for two 194 bulbs
Old Mar 30, 2008 | 04:18 PM
  #33
trial0r's Avatar
black c300 sport p1
that does seem like a lot of work but it looks so much nicer
Old Mar 30, 2008 | 09:10 PM
  #34
aowhaus's Avatar
2008 C300 Sport 4matic
if you are worried about the potential problems with using LED bulbs, why not get a pair of Polarg B1-Hybrid Hyper White M-4 bulbs instead?
GPI has these bulbs for the headlight eyebrows and it looks very nice:
Old Mar 31, 2008 | 12:49 AM
  #35
benzo-boi's Avatar
2008 C300 Sport Sedan: Panarama Roof, P2, Multimedia
Where did you get your resistors and led bulbs at? Were they hard to install?
Old Mar 31, 2008 | 02:45 PM
  #36
CLS63
https://mbworld.org/forums/showthrea...=1#post2738870
It is not hard if you are mechanically inclined. The resistors DO get warm/hot though so you have to mount them where they will do their job without touching anything that will melt or burn.
Old Mar 31, 2008 | 04:01 PM
  #37
misterng's Avatar
2008 W204
Here is PIAA X-treme White Wedge Bulb, type 194 W5W
http://www.xtremewhite.com/ORD-Light...52-1-1-1-1.cfm
Old Apr 4, 2008 | 12:53 AM
  #38
Savage c-300's Avatar
C300 Sport, MM, P1
i followed Snows advice and was able to switch out the license plate bulb and both trunk lights with super white bulbs. they look much better.
Old Apr 4, 2008 | 12:54 AM
  #39
C300 Sport, MM, P1
i changed out my eyelid bulbs to hyper white and they are no where as bright as yours aowhaus
Old May 2, 2008 | 06:01 AM
  #40
Turboxer's Avatar
Marin Palisades Trail
Got them at home! I' ll show you when installed.
PIAA XTREME WHITE 5W
Old May 2, 2008 | 09:06 AM
  #41
dalazernet's Avatar
2020 GLC300 4MATIC
Yea the Led's in White.. Im pretty sure i can figure it out.. just posted a question incase someones done it b4.. so i can be in and out of there..
I grabbed a pair from my friend at the lexus dealership (white 4300K).(yes... they will fit) ..So im gana post some pics when im done... maybe underglow(if i get really bored waiting for an oem backup camera from MB)
Thanks Guys
OMG it resumes on the W204 forum now... I can't believe how long that original LED license plate bulb topic will go on...
PS -- I _still_ want it.
- Eric
Old May 5, 2008 | 07:39 AM
  #42
Turboxer's Avatar
I installed them yesterday...the light is weak, I don't like the result, but I will not disassembly again to look for another bulb.
Old May 5, 2008 | 07:42 AM
  #43
Turboxer's Avatar
I noticed that our stock original bulbs are blue-coated, so there is nothing to do with them. Easy to change all, but nothing to improve unless you install leds...a difficult mission
