Smoke from a cold start...
Old Apr 21, 2008 | 10:36 AM
tw1nny03's Avatar
2008 C300
I have a new 2008 C300 with ~500miles on it.
I noticed sat morning and this morning, when started the car from a cold, there was a big puff of light-blueish smoke coming from the tailpipes. Its just one puff a smoke and it stops. I know blue means oil.
Well, I got my gf to drive the car while I was following her to see if it smokes while driving and acceleration. The car does not smoke while driving. It just smokes only on the first cold start.
Does anyone else have this issue? Any idea what is wrong?
Thanks,
Twin
Old Apr 21, 2008 | 10:56 AM
ohlord's Avatar
Valve guides
Have the dealer check it out,put them on notice that something is going on out of the normal and that way you have it documented in case anything crops up.
The car is under warranty so it should be no problem.
ohlord
Old Apr 21, 2008 | 11:00 AM
AMGfan's Avatar
06 SL65 / 97 993tt /11 Suburban/ 2012 GTR (AMG è la mia Famiglia la Bestia è la mia protezione)
ohlord
+1...Even if it is nothing...make sure it is documented you told your SA. Make sure you are aware of the date and time you talked to MB. Your better off being overly paranoid...
Old Apr 21, 2008 | 12:39 PM
ColoradoDriver's Avatar
2011 E350 Sport 4matic
Usually the cause of such behavior is oil getting past the valve guide oil seals while the engine is turned off. Drips down slowly into the combustion chambers. On engine start, that oil is burned, thus creating initial puff of light blue smoke. Will not see the smoke later, because the leaks are so minor. Hopefully, that is not the case with your engine.
Old Apr 21, 2008 | 01:46 PM
tw1nny03's Avatar
2008 C300
I scheduled an appointment with the dealer on wednesday. What could cause the oil getting ps the valve guide on a NEW car?
Old Apr 21, 2008 | 05:22 PM
theinmoe's Avatar
C350
Thanks,
Twin
I noticed samething when mine has 300 miles. Same blueish puff. Now I have 1200 miles on it and I dont see it anymore. Will check it again for sure.
Old Apr 21, 2008 | 05:59 PM
tw1nny03's Avatar
2008 C300
So, the puff of smoke just went away on its own on ur car?
Old Apr 21, 2008 | 06:15 PM
Cygnus X1's Avatar
09 C300 (on order).. 03 Marauder.. 90 5.0
Don't let the SA tell you it's normal either because it isn't.....have them perform a leak down test if they are giving you lame excuses.
Old Apr 21, 2008 | 07:46 PM
tw1nny03's Avatar
2008 C300
Yes, my service manager said he's gonna run some checks on it. It didnt say it was normal. Im gonna ask them to run a leak down test and a compression test.
Old Apr 21, 2008 | 09:13 PM
nyca's Avatar
is the car overfilled with oil? can the electronic dipstick-less system report that?
Old Apr 21, 2008 | 09:56 PM
Cygnus X1's Avatar
That's good to hear...good luck.
Old Apr 21, 2008 | 11:51 PM
AMGfan's Avatar
Glad to hear he isn't blowing off your concerns...keep us posted!
Old Apr 22, 2008 | 01:58 PM
tw1nny03's Avatar
2008 C300
I'll keep you guys posted. Im dropping the car off wednesday morning.
Its all good. Im driving the GTO around now. I just got long tubes installed. I love driving the goat, but I hate the gas mileage. lol
Old Apr 24, 2008 | 11:46 AM
theinmoe's Avatar
C350
yes, I guess. I checked last couple of days and no blue smoke at morning cold start. Last time when I noticed that was during clear bra install. Car's front was on 15 degree ramp slope for 4hr and when it started I saw the blue puff.
Where did you get this check, mine bought from North Houston.
